HELLO,
I WANT A HELP TO MODIFY THIS ROUTINE THAT LEE MAC WROTES.
I WANT TO SELECT MANY BLOCKS ON ONE SELECTION METHOD.
THANKS ,
(defun c:bsel ( / att atx blk cnt ent enx flg idx sel str tag )
    (setq blk (strcase (getstring t  "\nSpecify block name <any>: "))
          tag (strcase (getstring "\nSpecify attribute tag <any>: "))
          str (strcase (getstring t (strcat "\nSpecify attribute value" (if (= "" tag blk) ": " " <any>: "))))
    (if (not (= "" str tag blk))
        (if
            (and
                (setq sel
                    (ssget "_X"
                        (append
                           '((000 . "INSERT"))
                            (if (not (= "" tag str)) '((066 . 1)))
                            (if (/= "" blk) (list (cons 2 (strcat "`*U*," blk))))
                            (if (= 1 (getvar 'cvport))
                                (list (cons 410 (getvar 'ctab)))
                               '((410 . "Model"))
                    (repeat (setq idx (sslength sel))
                        (setq ent (ssname sel (setq idx (1- idx)))
                              enx (entget ent)
                        (cond
                            (   (not (or (= "" blk) (wcmatch (strcase (LM:name->effectivename (cdr (assoc 2 enx)))) blk)))
                                (ssdel ent sel)
                            (   (member (cdr (assoc 66 enx)) '(nil 0)))
                            (   (progn
                                    (setq att (entnext ent)
                                          atx (entget  att)
                                          flg nil
                                    (while
                                        (and (= "ATTRIB" (cdr (assoc 0 atx)))
                                            (not
                                                (and
                                                    (or (= "" str) (wcmatch (strcase (cdr (assoc 1 atx))) str))
                                                    (or (= "" tag) (wcmatch (strcase (cdr (assoc 2 atx))) tag))
                                        (setq att (entnext att)
                                              atx (entget  att)
                                    (= "SEQEND" (cdr (assoc 0 atx)))
                                (ssdel ent sel)
                    (< 0 (setq cnt (sslength sel)))
                (princ (strcat "\n" (itoa cnt) " block" (if (= 1 cnt) "" "s") " found."))
                (sssetfirst nil sel)
            (princ "\nNo blocks found.")
;; Block Name -> Effective Block Name  -  Lee Mac
;; blk - [str] Block name
(defun LM:name->effectivename ( blk / rep )
    (if
        (and (wcmatch blk "`**")
            (setq rep
                (cdadr
                    (assoc -3
                        (entget
                            (cdr (assoc 330 (entget (tblobjname "block" blk))))
                           '("acdbblockrepbtag")
            (setq rep (handent (cdr (assoc 1005 rep))))
        (cdr (assoc 2 (entget rep)))
        blk
What do you mean by this?
HELLO LEE MAC,
I DON'T SPEAK ENGLISH WELL.
FOR EXAMPLE:
Specify block name --   ANY BLOCK
Specify attribute tag--ANY TAG
AND HERE I WANT  TO ENTER MULTIBLE VALUES
Specify attribute tag-- 84,90,100,...……….
AND ALL THE BLOCKS I WANT TO SELECT IT BY THIS VALUES.
THANK YOU
The program already accepts wildcards, therefore you should be able to separate multiple values with commas.
