hi everyone,
i was wondering if is there any lisp code to lock drawing in AutoCAD
it could be like that :
(defun c:SomeThingsToDo()
  (LockDrawing)
  (DoSomeThings)  ;which contains many drawing proccess
  (UnLockDrawing)
i think it could do major speedup on my lisp program
thanks
I think any gain in speed would be negligible unless you're working on a 386-25MHz computer. In which case I'd say it's time to buy a new computer.
What kinds of drawings do you work with?
How large is a typical drawing file?
What "things" would you be doing while the drawing is locked?
Doesn't locking and unlocking the drawing take time just as well? Would the time these actions take be offset to any great degree by what is accomplished inbetween issuing these two commands?
thanks for quick reply
when we use any code include "(Command)" (for example (Command "ucs" "w")) AutoCAD draws the whole scene and we know that autocad has its own drawing engine (not any others like opengl or direct3d) so it takes a lot of time and i design ships so they have a lot of objects (some times our files size are being over 150 mb) anyway let say average fps (frame per second) is 20 on a big project file so a lisp function is gonna use a lot of "command" code like 100 thousand or something so it takes 83 minutes useless drawing. 83 minutes is a huge time for wasting
and you said
"Doesn't locking and unlocking the drawing take time just as well? Would the time these actions take be offset to any great degree by what is accomplished inbetween issuing these two commands?"
i dont mean locking every one of object indivudualy, i'm asking is there a locking code just blocking drawing thats all
thanks
Hmm... This probably not what you are looking for, but this is a locking lisp. Used to lockup drawings to kind of protect them on the copyright issues and stuff... Haven't explored all of it, but maybe you might find a way to work with it... Btw, I don't know the author...
Btw, Hidding layers, freezing or locking them up them do make the whole thing smoother, when I'm dealing with large files with complex drawing I use the layer management a lot. You probably know about this, but freezing the whole drawing or locking all the layers can be done just going in layer managemente hitting select all and clickin on the locking icon, maybe the freezing, w/e.
8D hope I could help you somehow
---- EDIT ----
AHHH, just to mention, ALWAY, I repeat, ALWAYS, save a backup of your drawing before using this lisp even the drawing being 150 mb large. hehe
Like, save a backup, open one of them, the original or the backup which would pretty much be the same, and lock ONE of them, that one will be locked from now on if you save it that way. And I believe there's no going back from that point for the locked up drawing.
Lockup.lsp
by the way when i'm saying drawing i dont mean the file, i mean process of scene (viewport) drawing
thanks, i think your way is the only way for speedup unless autolisp doesnt have any kind of easy way
if i cant find any easy solution i will develop a freez unfreez manager anyway
and thanks for the advice :D
does your LISP have to contain command expressions? Its a long time since I wrote any LISP but I don't remember using command very often.
Maybe one of the code gurus can put me right.
well for example you have to do some calculates with points of every objects in your file, you have to use "trans" command for transformation in world coordinate system you gotta use (command "ucs" "en" NextObject) and (command "ucs" "w")
or you may want to draw some polyline so you gotta use (command NextPoint) for ever y point on polyline ofcourse after the (command "pline")
or you may want to move things so you use :
(command "move" TheObject)
(command "")
(command (list 0 0 0))
(command (list moveX moveY moveZ))
maybe there are other ways to do these kind of things for example (entmod) (entupd) but i tghought maybe i could use block drawing and skim with easy ways
