CAD Panacea Posted September 11, 2019 Posted September 11, 2019 If you’ve ever seen this message in AutoCAD when trying to detach an xref, then you may have been a bit confused as to what to do next. You might think that “Multiple References” means the Xref is inserted more than once, but it could be another problem. The Autodesk tech bulletin on this says that a likely cause is that “The xref has been defined within a block in the drawing, probably coming in via a copy-paste action from another file.“ Okay, great, but how are you supposed to figure out which block contains a copy of the xref? In AutoCAD 2019 and earlier, this was the issue. But in AutoCAD 2020, the error message may** also tell you the name of the block that contains a copy of the reference, as shown below. 2019Command:Xref G8U8U-KGTCC_12009 has multiple references. Not detached.2020Command:Xref G8U8U-KGTCC_12009 has multiple references. Not detached."A$C66991LP8" Note that in 2020, the block name (in this case, an anonymous block named A$C66991LP8) is listed. At this point, you can edit, delete, and/or purge this block which should allow the Xref to be detached. ** “May”, because it’s possible that the Xref is contained in multiple blocks or some other odd scenario where it might not tell you a single block name. View the full article Quote
