Have You Tried: Adding Labels and Callouts With Multileaders
The AutoCAD Blog
The AutoCAD Blog
Some of the most common annotations in a drawing are labels and callouts. These convey various types of information and identifications depending on their content and symbology. The most advanced tool available for creating these types of objects in AutoCAD is the multileader tool and the MLEADER command.
Here are some examples of multileaders that you can create.
labels and callouts with multileaders
Just as the case with text or dimension styles, when you define several multileader styles, you can specify what type of multileader you want to use and then create them efficiently.
Learn more about how to get started using the Multileaders feature by following the step-by-step examples in the Have You Tried: Multileaders for Labels and Callouts topic.
Keep the Feedback Coming
Thanks for all the great feedback submitted so far. Because of the great feedback, we have been able to improve the topics in the AutoCAD Online Help system. Updated Help Topics contains a list of the most recently updated topics.
The best way to submit feedback is by using the “Was this helpful?” section located at the bottom of every Help topic. Let us know what you like or don’t like about a topic or provide suggestions for other subjects that you’d like to see covered in greater detail. The more specific your comments, the better.
The post Have You Tried: Adding Labels and Callouts With Multileaders appeared first on AutoCAD Blog.
KlNIYQHypWU
View the full article
