Look for Block in multiple files until found ? Alert if nothing.
merCADer
Hello CAD Community,
I created a lisp that calls for a block from an external .dwg, but then I realized that what if I end up with hundreds of blocks - then I would need to have hundreds of lisp for each of them and edit the lisp every time a new block gets added into the pool.
Fortunately, there are people better at this than me. :)
With the help from great people in the Autodesk forums we have managed to turn this lisp from - every block has its own lisp to a lisp that ask's for what block you want (via getstring) then inserts it in your active drawing.
Now, I want to explore options so here I am. :)
What I want to change here is instead of the lisp looking into a single .dwg it looks into multiple .dwg files until it finds the block with that name. I know the lisp would need to have multiple paths to look in to then have "if else" statements, I just dont know how to do it.
Here is the lisp:
(defun c:TST (/ tst1 s_path blk_b pt)
  (setq tst1 (getstring "enter test string:")
        s_path "../path/path1.dwg"
		blk_b T
  );end_setq
  (cond ((not (tblsearch "block" tst1))
          (steal s_path (list (list "Blocks" (list tst1))))
          (cond ( (not (tblsearch "block" tst1))
                  (alert (strcat "Error! Could not find block  \""  (strcase tst1) "\" in the libraries. please enter an existing block."))
                  (setq blk_b nil)
          );end_cond
  );end_cond
  (cond (blk_b
          (setq pt (getpoint "\nSpecify insertion point: "));
          (command "-insert" tst1 pt);
          (while (= (logand (getvar 'cmdactive) 1) 1)(command ""))
  );end_cond
);end_defun
Thanks!
I think I have figured it out, but please do suggest if this is an effecient way of doing it as I am a novice with Lisps.
(defun c:TST2 (/ tst1 s_path blk_b pt)
        s_path1 "../path/path1.dwg"
		s_path2 "../path/path2.dwg"
		s_path3 "../path/path3.dwg"
		blk_b T
  );end_setq
          (steal s_path1 (list (list "Blocks" (list tst1))))
                  (steal s_path2 (list (list "Blocks" (list tst1))))
                  (setq blk_b nil)
          );end_cond
  );end_cond
                  (steal s_path3 (list (list "Blocks" (list tst1))))
                  (setq blk_b nil)
          );end_cond
  );end_cond
                  (setq blk_b nil)
          );end_cond
  );end_cond
  (cond (blk_b
  );end_cond
);end_defun
Ok. It works but it doesnt.
Anything beyond s_path1 gets a "nil" the first time you run it, but if you run it again, it does insert the block.
Im not sure how to fix this - but I will try.
couple of weeks ago I was desperately searching the network for a missing block and modified a routine I used to search for a string by means of a quick / dirty fix. It uses odbx and searches all drawings in a folder / subfolders and crashes out as soon as a drawing is found containing the block with a hard exit (very dirty) but hey , it was all I needed at the time. I believe I did change the routine a little bit to show a better progress indicator but I don't have that version here at home. So its only search , no insert...
; find block name - written by rlx 12 sep 2019
; uses odbx to process entire folder , type 'fbn' on commandline to start program
; some timings :
; Processed 1012 drawings in 151.234 secs.  - 6.69 dps
; Processed 11355 drawings in 5124.609 secs - 2.21 dps
(defun c:fbn (/ err acapp actdoc actspace acdocs all-open objdbx sf dwg-list start ssl Express ProgBar
                prog-base blk-name)
  (_init) (_exit) (terpri) (princ))
(defun find_block_name  ( $dwg / odbxdoc layout obj )
  (if (setq odbxdoc (odbx_open $dwg))
      (vlax-for b (vla-get-blocks odbxdoc)
        (if (and (eq "AcDbBlockTableRecord" (vla-get-Objectname b))
                 (equal (strcase (vla-get-name b)) blk-name))
          (progn (alert (strcat "Found it in dwg " $dwg)) (princ $dwg) (exit)) ; not pretty but hey...i was in a hurry
;--- Init ----------------------------------------------- Begin of Init section -------------------------------------------------- Init ---
(defun _init  () (vl-load-com)
   ; initialize ini engine
  (if (not (vl-file-directory-p (setq prog-base (strcat (getvar 'MYDOCUMENTSPREFIX) "\\lisp\\"))))
    (vl-mkdir prog-base))
  (setq err *error*)  (defun *error* (s) (princ s)(_exit))
  (defun _exit () (odbx_releaseall)(and Express ProgBar (acet-ui-progress))(setq *error* err)) (odbx_init)
  (if (and
        (setq blk-name (getstring "Blockname to find : " T)) (not (equal (setq blk-name (strcase blk-name)) ""))
        (setq sf (getfolder "Select source folder for drawings")) (vl-consp (setq dwg-list (fido sf)))
    (progn (setq start (car (_vl-times)))
       (princ (strcat "\nProcessing " (setq l (itoa (length dwg-list))) " drawings..."))
           (progress)(if Express (setq ProgBar (acet-ui-progress "Scanning..." (length dwg-list))))
       (foreach dwg dwg-list
         (if Express (acet-ui-progress -1))
         (find_block_name dwg)
         (if Express (setq ProgBar (acet-ui-progress)))
             (setq blk-name-list nil)
       (princ (strcat "\n\nProcessed " l " drawings in " (rtos (/ (- (car (_vl-times)) start) 1000.) 2 4) " secs.")))
    (princ "\nNo files to process...")
(defun progress ()
  (setq Express (and (vl-position "acetutil.arx" (arx))
             (not (vl-catch-all-error-p (vl-catch-all-apply (function (lambda nil (acet-sys-shift-down)))))))))
;--- Init ------------------------------------------------ End of Init section --------------------------------------------------- Init ---
;--- Scripting Object --------------------------------- Begin of Scripting Object ------------------------------------ Scripting Object ---
; Thanks to TonyT - just compressed and tweaked it a little bit
(defun load_fso_scripting  (/ server fso:progid fso:prefix)
  (setq    fso:progid "Scripting.FileSystemObject"    fso:prefix "wsh-")
  (if (not wsh-get-drives)
    (if    (not (setq server (cogetclassserver fso:progid))) (alert "Error: Windows Scripting Host is not installed")
      (vlax-import-type-library    :tlb-filename server :methods-prefix fso:prefix    :properties-prefix fso:prefix :constants-prefix
    (strcat ":" fso:prefix)))))
(defun progid->clsid (progid) (vl-registry-read (strcat "HKEY_CLASSES_ROOT\\" progid "\\CLSID")))
(defun cogetclassserver (progid) (cogetclassproperty progid "InprocServer32"))
(defun cogetclassproperty  (progid property / clsid)
  (if (setq clsid (progid->clsid progid)) (vl-registry-read (strcat "HKEY_CLASSES_ROOT\\CLSID\\" clsid "\\" property))))
; Find Drawing Objects - test : (setq lst (fido (dos_path "c:/temp/lisp"))) works also with networkpaths
(defun fido  ($f / fso fld rslt)
  (load_fso_scripting) (setq fso (vla-getinterfaceobject (vlax-get-acad-object) "Scripting.FileSystemObject"))
  (setq    fld  (wsh-getfolder fso $f) rslt (fifo fld "*.dwg"))(vlax-release-object fld)(vlax-release-object fso)  rslt)
; find in folders fl=file ,fls=files, sf=subfolder, sfl=subfolderlist, res=result
(defun fifo  (%dir %ext / fl fls sf sfl res)
  (vlax-for fl    (setq fls (wsh-get-files %dir))
    (if    (wcmatch (strcase (wsh-get-name fl) t) %ext) (setq res (cons (wsh-get-path fl) res)))(vlax-release-object fl))
  (vlax-release-object fls)
  (vlax-for sf (setq sfl (wsh-get-subfolders %dir)) (setq res (append res (fifo sf %ext)))(vlax-release-object sf))
  (release_me (list sfl)) res)
;--- Scripting Object ---------------------------------- End of Scripting Object ------------------------------------- Scripting Object ---
;--- Odbx ------------------------------------------------- Begin Odbx Section --------------------------------------------------- Odbx ---
(defun odbx_init  (/ acver)
  (setq    acapp (vlax-get-acad-object) actdoc (vla-get-activedocument acapp) actspace (vla-get-modelspace actdoc)
    acdocs (vla-get-documents acapp) acver (atoi (getvar "ACADVER"))
    all-open (vlax-for dwg acdocs (setq all-open (cons (strcase (vla-get-fullname dwg)) all-open)))
    objdbx (vl-catch-all-apply 'vla-getinterfaceobject
         (list acapp (if (< acver 16) "objectdbx.axdbdocument" (strcat "objectdbx.axdbdocument." (itoa acver))))))
  (if (or (void objdbx) (vl-catch-all-error-p objdbx)) (setq objdbx nil)))
(defun odbx_releaseall    ()
  (mapcar '(lambda (x) (if (and (= 'vla-object (type x)) (not (vlax-object-released-p x)))(vlax-release-object x))(set (quote x) nil))
       (list odbxdoc acdocs objdbx actspace actdoc acapp)) (gc))
(defun odbx_open  (dwg)
  (if objdbx (if (member (strcase dwg) all-open)
           (odbx_open_copy (findfile dwg))(vl-catch-all-apply 'vla-open (list objdbx (findfile dwg))))) objdbx)
(defun odbx_open_copy  (dwg / copy)
  (vl-file-copy (findfile dwg) (setq copy (vl-filename-mktemp nil nil ".dwg")))(vla-open objdbx (findfile copy))  objdbx)
;--- Odbx -------------------------------------------------- End Odbx Section ---------------------------------------------------- Odbx ---
;--- + + + --------------------------------------------- Begin of tiny lisp section --------------------------------------------- + + + ---
(defun wait  (sec / stop) (setq stop (+ (getvar "DATE") (/ sec 86400.0))) (while (> stop (getvar "DATE"))))
;(defun void  (x) (if (member x (list "" " " "  " "   " "       " nil '())) t nil))
(defun void (x) (or (null x) (and (= (type x) 'STR) (= "" (vl-string-trim " \t\r\n" x)))))
(defun e2v (e)(vlax-ename->vla-object e)) ;||; (defun v2e (o)(vlax-vla-object->ename o)) ;||; (defun _type (e)(cdr (assoc 0 (entget e))))
(defun release_me  (lst)
  (mapcar '(lambda (x)(if (and (= 'vla-object (type x))(not (vlax-object-released-p x)))(vlax-release-object x))(set (quote x) nil)) lst))
(defun getfolder  (msg / fl sh)
  (if (and (setq sh (vlax-create-object "Shell.Application"))(setq fl (vlax-invoke sh 'browseforfolder 0 msg 0 "")))
    (setq fl (vlax-get-property (vlax-get-property fl 'self) 'path))(setq fl nil))(release_me (list sh)) fl)
(defun get_block_name (b)
  (cond ((vlax-property-available-p b 'effectivename) (vla-get-effectivename b)) ((vlax-property-available-p b 'name) (vla-get-name b))))
; make sure path is corect for scripting object (dos_path (strcat (getvar "dwgprefix") (getvar "dwgname")))
(defun dos_path     ($p) (if (= (type $p) 'str) (strcase (vl-string-translate "/" "\\" $p)) ""))
;--- + + + ---------------------------------------------- End of tiny lisp section ---------------------------------------------- + + + ---
(princ "\nFind Block Name - RLX 12 sep 2019 : Type 'FBN' on commandline to start program\n")
; (c:fbn)
Edited by rlx
Something similar its a DOS command findstr, I am forever trying to find a vl syntax so you can do findstr closest *.lsp and it will display all the lisps that have that word in it. I have it as a bat so looks in lisp files area.
Back to the post have you looked at palettes or a block library of dwg's it sounds to me like your reproducing the same thing multiple times if you forget the block name.
