svorgodne Posted October 4, 2019 Posted October 4, 2019 Hello everyone, is there any possibility to add some formulas to the parameters inside a dynamic block? I am adding a drawing with the example of a two wing door wich I added some linear parameters , but it is not working as I expected. There are some conditions tho. That's the reason Iwould like to attach a formula. Can anyone help me? Thanks in advance TestDoor.dwg Quote
BIGAL Posted October 5, 2019 Posted October 5, 2019 You have 3 constraint but only 2 can be fixed the 3rd must be calculated. You can click on the text like distance3 and make it =Distance1+Distance2. For me I would use a lisp to do the "is less than" and making decisions then update the block. Quote
