lisp to annotate differences of two points X Y!
Hi
Could enyone write autolisp that annotate differences between two points!
Br.
Margus
I would suggest representing the symbol using an attributed dynamic block, with the attributes populated with the coordinate differences - this way, the symbols may be manipulated as a single object and the attribute values may be extracted to an external file if required.
Just for fun, I thought I would dig through the old toolbox. There are some basic tools that everyone should already have when new writing routines.
I attempted to make this simple to understand, with many variables that are named as to their function, and comments within the code to follow what is going on.
(defun c:2Pnts (/	 pnt1	  pnt2	   deltaX   deltaY   deltaZ
		midpt	 dist	  vertex   lineX    lineY    txtPntX
		txtPntY	 txthgt
  ;; First, start with the basic toolbox
  (setq pnt1 (getpoint "\nSelect first point: "))
  (setq pnt2 (getpoint "\nselect second point: "))
  (setq deltaX (- (car pnt2) (car pnt1)))
					;this is the change in x coords
  (setq deltaY (- (cadr pnt2) (cadr pnt1)))
					;this is the change in y coords
  (setq deltaZ (- (caddr pnt2) (caddr pnt1)))
					;this is the change in z coords
  (setq	midpt				;this will calculate the midpoint
	 (list
	   (+ (car pnt1) (* deltaX 0.5))
	   (+ (cadr pnt1) (* deltaY 0.5))
	   (+ (caddr pnt1) (* deltaZ 0.5))
  (setq dist (sqrt (+ (expt deltaX 2) (expt deltaY 2) (expt deltaZ 2))))
					;this will calculate the distance between points
  ;; Second, we can print this information to the text screen
  ;;(textscr)  ;this can be uncommented to make the text screen pop-up
  (princ "\nPoint 1 location: ")
  (princ pnt1)
  (princ "\nPoint 2 location: ")
  (princ pnt2)
  (princ
    (strcat "\nChange in x direction: " (rtos deltaX 2 1))
  (princ
    (strcat "\nChange in y direction: " (rtos deltaY 2 1))
  (princ
    (strcat "\nChange in z direction: " (rtos deltaZ 2 1))
  (princ "\nMidpoint between points: ")
  (princ midpt)
  (princ
    (strcat "\nDistance between points: " (rtos dist 2 5))
  (princ
    (strcat "\nDistance to midpoint: " (rtos (/ dist 2) 2 5))
  (princ (strcat "\nAngle from point A to point B: "
		 (rtos (angle pnt1 pnt2) 2 5)
		 " radians or "
		 (rtos (/ (* (angle pnt1 pnt2) 180.0) pi) 2 2)
		 " degrees. "
  (princ (strcat "\nAngle from point B to point A: "
		 (rtos (angle pnt2 pnt1) 2 5)
		 " radians or "
		 (rtos (/ (* (angle pnt2 pnt1) 180.0) pi) 2 2)
		 " degrees. "
  ;; Now, we can look at what to do with all this information
  (vl-cmdf "_.point" pnt1)
  (vl-cmdf "_.point" pnt2)
  (setq vertex (list (car pnt1) (cadr pnt2))) ;vertex of symbol
  (setq lineX (list (+ (car pnt1) (/ deltaX 2)) (cadr pnt2)))
					;endpoint of line in x-direction
  (setq lineY (list (car pnt1) (+ (cadr pnt2) (/ deltaY 2))))
					;endpoint of line in y-direction
  (setvar "osmode" 0)			;turn off snaps
  ;;make x/y lines
  (vl-cmdf "_.line" lineX vertex lineY "")
  ;;make arrow in x-direction
  (if (< (car pnt1) (car pnt2))
    (vl-cmdf "_.line"			;first/fourth quadrant
	     (list (- (car lineX) (abs (* 0.125 deltaX)))
		   (+ (cadr lineX) (abs (* 0.0625 deltaY)))
	     lineX
		   (- (cadr lineX) (abs (* 0.0625 deltaY)))
    ;;else
    (vl-cmdf "_.line"			;second/third quadrant
	     (list (+ (car lineX) (abs (* 0.125 deltaX)))
	     lineX
  )					;end if
  ;;make arrow in y-direction
  (if (< (cadr pnt1) (cadr pnt2))
    (vl-cmdf "_.line"			;first/second quadrant
	     (list (+ (car lineY) (abs (* 0.0625 deltaY)))
		   (- (cadr lineY) (abs (* 0.125 deltaX)))
	     lineY
	     (list (- (car lineY) (abs (* 0.0625 deltaY)))
    ;;else
    (vl-cmdf "_.line"			;third/fourth quadrant
		   (+ (cadr lineY) (abs (* 0.125 deltaX)))
	     lineY
  )					;end if
  ;; add text to drawing
  (setq
    txtPntX (list (+ (car lineX) (* 0.21875 deltaX)) (cadr lineX) 0.0)
  (setq
    txtPntY (list (car lineY) (+ (cadr lineY) (* 0.21875 deltaY)) 0.0)
  (setq txthgt (abs (* 0.0625 deltaX)))
  (entmakex (list (cons 0 "TEXT")
		  (cons 10 txtPntX)
		  (cons 40 txthgt)
		  (cons 71 0)
		  (cons 72 4)
		  (cons 11 txtPntX)
		  (cons 73 0)
		  (cons 1 (rtos deltaX 2 2))
		  (cons 10 txtPntY)
		  (cons 40 txthgt)
		  (cons 71 0)
		  (cons 72 4)
		  (cons 11 txtPntY)
		  (cons 73 0)
		  (cons 1 (rtos deltaY 2 2))
That should be enough to get you started.
This question was also answered somewhere else as well.
I am like lee
On 10/10/2019 at 10:29 PM, Margusrebase said:
Hi
Br.
Margus
old thread? -> Theorical & actual point
another idea is to draw a line between 2 points, then FIELD query 'delta' properties (WCS)
haven't tried dynamic block sounds good idea, with arrow shx (shape file) ?
  • 1 year later...
Hi All.
i have a point cloud and i need to know the height of trees.
So i have to pick 2 points in the point cloud and as result the text from that diference should apear in the drawing clicking where i want it o be.
can you help me please.
is so send to my email.
Thank you!
