Pugazh
Setvar 'Snapang using lisp with greater-than or equal condition
Pugazh
(defun RtoD (nbrOfRadians)
  (/ (* nbrOfRadians 180.0) pi)
(defun DtoR (nbrOfDegrees)
  (* (/ nbrOfDegrees 180.0) pi)
(if (>= (cvunit (getvar 'snapang) "radians" "degrees") 180.0)
    (setvar 'snapang (- (cvunit (getvar 'snapang) "radians" "degrees") 180.0))
Hi, i think this code is totally wrong please help me!
Edited by Pugazh
Share this post
Link to post
Pugazh
    (command "_.snapang" (- (cvunit (getvar 'snapang) "radians" "degrees") 180.0))
This code is working fine :) :beer:
Share this post
Link to post
Lee Mac
The code could alternatively be written:
(if (<= pi (getvar 'snapang))
    (setvar 'snapang (- (getvar 'snapang) pi))
Or simply:
(setvar 'snapang (rem (getvar 'snapang) pi))
  • Thanks 2
Share this post
Link to post
Pugazh
thanks @Lee Mac :beer:
Edited by Pugazh
Share this post
Link to post
Pugazh
Hi @Lee Mac,
i have some doubt about snapang. please see the attached file.
i want as per attached image have two condition in one lisp code it's possible? (must be check the two condition at the same time)
Share this post
Link to post
dlanorh
(if (< (/ pi 2) (getvar 'snapang) (* (/ pi 2) 3)) (setvar 'snapang (+ (getvar 'snapang) pi)))
  • Thanks 1
Share this post
Link to post
Lee Mac
Alternatively, without if statements:
(setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)))
  • Thanks 1
Share this post
Link to post
Pugazh
How to combine ? one if condition :(
(if (= (getvar 'snapang) (/ pi 2)) (setvar 'snapang (/ pi 2)))
(if (= (getvar 'snapang) (* (/ pi 2) 3)) (setvar 'snapang (/ pi 2)))
Share this post
Link to post
tombu
(if (= (setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)))(* (/ pi 2) -1))(setvar 'snapang (/ pi 2)))
Now it works!
Edited by tombu
coding error
  • Thanks 1
Share this post
Link to post
Pugazh
Now it works!
thank you @tombu :beer:
Share this post
Link to post
Pugazh
I have another doubt!
If i set snapang any angle, it should be automatically change to as per autocad dimension text rotation. it's possible ?
Share this post
Link to post
tombu
As I do Civil / Survey drawings whose plan views are all twisted in each viewport I wrote this to set selected block insert, text, mtext, & dimtext angles Horizontal.
I've modified it for you to use the snap angle if the view isn't twisted.
;| ;| https://forums.augi.com/showthread.php?171018-rotate-text-to-horizontal-in-viewport&p=1332928&viewfull=1#post1332928
   http://www.theswamp.org/index.php?topic=55060.msg595136#msg595136
   https://www.cadtutor.net/forum/topic/68912-setvar-snapang-using-lisp-with-greater-than-or-equal-condition/?tab=comments#comment-557172
Set block insert, text, mtext, & dimtext angle Horizontal by Tom Beauford
 (load "TextHoriz.lsp") TextHoriz
   Macro: ^P(or C:TextHoriz (load "TextHoriz.lsp"));TextHoriz
   Command line: (load "TextHoriz.lsp") TextHoriz |;
(defun c:TextHoriz (/ ss1 num cnt viewtwist snapang etype obj dimr)
  (setq ss1 (ssget '((0 . "insert,mtext,text,dimension")))
        num (sslength ss1)
        cnt 0
        viewtwist (getvar "viewtwist")
  (if (or (= snapang (* (/ pi 2) -1)) (= snapang (* (/ pi 2) 3)))(setvar 'snapang (/ pi 2)))
  (if(/= viewtwist 0.0)
	(repeat num
	  (setq ent (ssname ss1 cnt)etype (cdr(assoc 0 (entget ent))))
	  (setq obj (vlax-ename->vla-object ent))
	  (if(= etype "DIMENSION")
		  (setq dimr (- (vla-get-Rotation obj)viewtwist))
		  (vla-put-TextRotation obj dimr)
		(vla-put-Rotation obj (- viewtwist))
	  (setq cnt (1+ cnt))
	) ; repeat
	(repeat num
		  (setq dimr (+ (vla-get-Rotation obj)snapang))
		(vla-put-Rotation obj snapang)
	  (setq cnt (1+ cnt))
	) ; repeat
;	(princ "\nNo TWist in Viewport.")
  ) ; if
Edited by tombu
Updated to fix both snapang 270 or -90.
  • Thanks 1
Share this post
Link to post
Pugazh
Thank you @tombu!!
   I think my question is wrong :(  , How to take snap angle in aligned dimensions text rotation ? if i draw dimension text automatically rotated as per snap angle.
i need this snap angle code with if conditions
like this
Share this post
Link to post
tombu
5 minutes ago, Pugazh said:
Thank you @tombu!!
like this
I modified the code for that 38 minutes ago, have you tried the updated code?
Share this post
Link to post
Pugazh
    (command "_.snapang" "_non" pt1 "_non" pt2)
@tombu , I did not change rotation.
I have two points, pt1 is block mid point, pt2 is block insert point.
now snapang is 270 from the pt1 & pt2. i use this code sometimes update snapangle 90 but sometimes not update :( why i know :(
Share this post
Link to post
tombu
I've updated the code to correct snapang of either (* (/ pi 2) 3) or (* (/ pi 2) -1).
Edited by tombu
  • Thanks 1
Share this post
Link to post
Pugazh
10 hours ago, Lee Mac said:
@Pugazh Assuming I've understood what you are looking to achieve, is this program of use to you?
thank you lee :) i got it your code :) :beer:
Share this post
Link to post
Lee Mac
Excellent - you're most welcome :)
Share this post
Link to post
