DYNAMO J. Posted October 19, 2019 Share Posted October 19, 2019 I want to draft panels using VBA or EXCEL data, anyone give the script for the same, i have attached drafting flow here, please see attached cad file. A Panel.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 20, 2019 Share Posted October 20, 2019 This would be the method etc its all been done before mainly in lisp. Get get say lower left point. Length & width draw a pline 4 sides Draw 4 plines that are the green offsets you know the co-ords of the 4 corner points. Take the Length /400 get x.xx you take the fix and work out the odd end measurements Draw the circles top bottom Work out the width = /400 etc Draw the circles. (defun c:panel ( / len wid pt1 pt2 pt3 pt4) (setq pt1 (getpoint "\nPick lower left Corner")) (setq Len (Getreal "\nEnter length")) (setq wid (Getreal "\nWidth")) (setq pt2 (polar Pt1 0.0 len)) (setq pt3 (polar pt2 (/ pi 2.0) wid)) (setq pt4 (polar pt3 pi len)) (command "pline" pt1 pt2 pt3 pt4 "c") ) (C:panel) Ok so for green lines do a change layer (setvar 'clayer "greenlines") you work out 3 new pts using polar command again (setq pt5 (polar pt1 (* 1.5 pi) off)) work out pt6 then (command "pline" pt1 pt5 pt6 pt2 "") redo for 3 other sides (setq num (fix (- (/ len 400.0) 1))) (setq off2 ( / (- len (* num 400.0)) 2.0)) Now work out some more points for the circles do again for 3 other sides Quote Link to comment Share on other sites More sharing options...
DYNAMO J. Posted October 22, 2019 Author Share Posted October 22, 2019 On 10/20/2019 at 8:32 AM, BIGAL said: This would be the method etc its all been done before mainly in lisp. Get get say lower left point. Length & width draw a pline 4 sides Draw 4 plines that are the green offsets you know the co-ords of the 4 corner points. Take the Length /400 get x.xx you take the fix and work out the odd end measurements Draw the circles top bottom Work out the width = /400 etc Draw the circles. (defun c:panel ( / len wid pt1 pt2 pt3 pt4) (setq pt1 (getpoint "\nPick lower left Corner")) (setq Len (Getreal "\nEnter length")) (setq wid (Getreal "\nWidth")) (setq pt2 (polar Pt1 0.0 len)) (setq pt3 (polar pt2 (/ pi 2.0) wid)) (setq pt4 (polar pt3 pi len)) (command "pline" pt1 pt2 pt3 pt4 "c") ) (C:panel) Ok so for green lines do a change layer (setvar 'clayer "greenlines") you work out 3 new pts using polar command again (setq pt5 (polar pt1 (* 1.5 pi) off)) work out pt6 then (command "pline" pt1 pt5 pt6 pt2 "") redo for 3 other sides (setq num (fix (- (/ len 400.0) 1))) (setq off2 ( / (- len (* num 400.0)) 2.0)) Now work out some more points for the circles do again for 3 other sides this is only rectangle script, please could you provide me script for whole object Quote Link to comment Share on other sites More sharing options...
