Hi All
first post as google & forum searches usually net what i'm chasing, but this is beyond me.
I have some code (previously posted by ASMI here) that returns the coordinates of each vertex in a polyline.
I now want to loop through this list and check for an an intersection between each segment of a polyline and 2 other points
what i have so far gets me the two endpoints, but from here i haven't a clue
(defun c:asdf (/ whoa pts ep1 ep2)
 (setq whoa (mapcar 'cdr(vl-remove-if '(lambda(x)(/= 10(car x)))(entget(car(entsel))))))
(setq pts (cdr whoa))
(setq ep1 (car pts))
(setq ep2 (cadr pts))
I'd suggest you use the 'nth' function to retrieve needed points from list. Get length of list with 'length' function. Set up a counter; first time through use pt1 & pt2; then pt2 & pt3; up through last point.
Thanks CarlB
you gave me an idea to use a 'while' in there with the length check
 (setq pts (mapcar 'cdr(vl-remove-if '(lambda(x)(/= 10(car x)))(entget(car(entsel))))))
(while (>= (length pts) 2)
 	(setq pts (cdr pts))
does this seem ok? i've never looped before
i also realised that my first lot of code stripped off the first vertex...oops
