Getting info from strings
saim
Hello again!
I mannaged to read some strings from a text file and place them on a list. When I tell cad to print them on screen, I get the following result:
Quote
("PV1;2;2" "PV2;6;6" "PV3;8;10")
That's what I expected, so I'm fine, so far.
Now I want to get those strings and convert them in information to draw something. Like a polyline from point (2,2) to (6,6) and to (8,10).
In other words: how do I get CAD to undertand that list as "the point 'PV1' has the x-coordinate equal 2 and the y coordinate equal 2", and so on?
The cue I used to change from one info to another is the ";" (semocolon) - is that ok or is there some kind of default?
I may need to make this issue a bit more complex, but I need that milestone to go further...
BTW, in case it matters how I got that line, I used the following code and the following text file contents:
(defun c:desenha( / dflt fname fl fil plt1)
	(setq dflt (strcat (getvar 'dwgprefix) (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)) )) ; dá um nome default pro arquivo
	(setq fname (getfiled "esse é o título da cx de diálogo" dflt "txt" 8)) ; usa a função getfiled pra procurar o arquivo
	(setq fl (open fname "r"))
	(while (setq fil (read-line fl))
		(if (not (null fil))
			(setq plt1 (append plt1 (list fil)))
		) ;end if
		) ;end while
	(close fl)
	(print plt1)
Quote
PV1;2;2
PV2;6;6
PV3;8;10
Hi,
An example of how to convert a list of strings to a list of coordinates based on your list if your list is always with the same form.
(foreach str '("PV1;2;2" "PV2;6;6" "PV3;8;10")
  (setq lst (cons (read (strcat "(" (vl-string-translate ";" "," (substr str 5)) ")")) lst))
You need to reverse the list afterwards.
You could use a function such as my String to List function to convert the string to a list using a supplied token, for example:
(defun c:desenha2 ( / des lst str txt )
    (if (setq txt (getfiled "Esse é o título da cx de diálogo" (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname))) "txt" 8))
        (if (setq des (open txt "r"))
                (while (setq str (read-line des))
                    (setq lst (cons (LM:str->lst str ";") lst))
                (close des)
                (if
                    (setq lst
                        (vl-remove nil
                            (mapcar
                                (function
                                    (lambda ( i / n x y )
                                        (if
                                            (and
                                                (wcmatch (car i) "PV*")
                                                (setq n (atoi (substr (car i) 3)))
                                                (setq x (distof (cadr  i) 2))
                                                (setq y (distof (caddr i) 2))
                                            (list n 10 x y)
                                lst
                    (entmake
                        (append
                            (list
                               '(000 . "LWPOLYLINE")
                               '(100 . "AcDbEntity")
                               '(100 . "AcDbPolyline")
                                (cons 90 (length lst))
                               '(070 . 0)
                            (mapcar 'cdr (vl-sort lst '(lambda ( a b ) (< (car a) (car b)))))
            (princ "\nUnable to open file for reading.")
        (princ "\n*Cancel*")
;; String to List  -  Lee Mac
;; Separates a string using a given delimiter
;; str - [str] String to process
;; del - [str] Delimiter by which to separate the string
;; Returns: [lst] List of strings
(defun LM:str->lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
Edited by Lee Mac
oh darn , too late again... awell...
(defun SplitStr ( s d / p ) (if (setq p (vl-string-search d s))(cons (substr s 1 p)
  (SplitStr (substr s (+ p 1 (strlen d))) d)) (list s)))
(defun istext (s)(if (= (type s) 'str) t nil))
(defun plc (p l c)(entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity")
  '(100 . "AcDbPolyline")(cons 8 l)(cons 90 (length p))(cons 70 c))(mapcar '(lambda (pt) (cons 10 pt)) p))))
(defun t1 (sl / pl )(and (vl-consp sl)(vl-every 'istext sl)(vl-every '(lambda (x)(wcmatch x "*;*;*")) sl)
   (vl-consp (setq pl (mapcar '(lambda (x)(mapcar 'atoi (cdr (SplitStr x ";")))) sl))) (plc pl "0" 0)))
; test : (t1 '("PV1;2;2" "PV2;6;6" "PV3;8;10"))
