Loft feature
I am trying to create a loft from 2 faces that meet but are not planar. I insert a 3d sketch then select the edges of the 2 non - planar faces and convert entities. I then try create a loft using the converted entities 3d sketch and another circular profile. Rebuild errors "Cannot make 2 planar end faces to cap the side sheet."
You can't make a loft from a single 3d sketch. Maybe you need a "Fill Surface".
"Selection Manager" is often used instead of creating a sketch... or to make multiple profiles-guides out of a single 3d sketch.
A picture would be helpfull.
