I made a search with my title but did not find anything about it.
I work with Autocad 2017
The question is how can i stretch 3D objects ?
Example: I have drawn an L64x64x6.4 angle and did some hole in it. All the data came from a fabrication drawing that i have.
The problem is that i will not fit (not able to insert bolts). It is a little bit too short.
Since the stretch command do not work, i have to change my 2D drawings and put the holes again (i use 3D align to position the holes pattern)
I'm not a 3D guru, so if you have some advice it would help me a lot.
Thanks !
Another option would be to use the Move Faces command.  This command can also be used to move a misplaced hole.
