Delete original and linked objects after offset.
I reattach the sample picture and the dwg file.
Sequence of the work.
1. Offset 7 mm by selecting a 30 mm long horizontal line.
2. The color changes to red for offset segments.
3.The length is reduced by 7 mm on the left and right vertical lines connected to the horizon.
4. The first 30mm horizontal line selected is deleted.
Had a think about this if plines then easy you get co-ordinates then make a choose L R U D and enter a difference +/- this will shrink / expand then use break, all done.
Confirm what the objects are, if lines then would make plines.
Edited by BIGAL
