The DIM STYLE settings are not allowing my tick marks to appear as the color of the layer I am  creating them in.
All other DIM lines are appearing in the color bylayer. How do I set it so ALL dim entities are at color bylayer.
Is your tick a standard item or a custom block? Make sure the color of the items in your block is ByBlock.
Not a block. DIM STYLE settings are ALL "Bylayer"
As CyberAngel asked, are you using a standard tick or a custom tick?
Your dimstyle tick is a block. If it's a standard tick then I'm not sure why you're having a problem with it, unless someone edited it. You should insert the tick into your drawing and make sure it's set up correctly, on Layer 0. If it's on a different layer, it will retain the color of the layer that's its created on, just like any other block.
