Sambuddy Posted December 5, 2019 Posted December 5, 2019 I am sure your question would be why not running a simple find command, but since I have so many blocks, my results would show 50 results each time - this is my way of simplifying the find command but no intention to replace - only to view. Is there a way to partially find/ locate a text, example: KRE-800 10291 (101 2065) if it could ignore <spaces> and not a perfect match rather partial match! Thanks (defun c:TEST (/ text ss) (setvar 'dynmode 3) (setvar 'dynprompt 1) (if (and (setq text (getstring T "\n >> Enter Antenna Model To Find: ")) (setq ss (ssget "_x" (list '(0 . "TEXT,MTEXT") (cons 1 text))))) (sssetfirst nil ss) ) ;end if (command "zoom" "o") (princ) ) ; end defun Quote
Lee Mac Posted December 5, 2019 Posted December 5, 2019 Change: (cons 1 text) to: (cons 1 (strcat "*" text "*")) Quote
Sambuddy Posted December 5, 2019 Author Posted December 5, 2019 did not succeed since it works for some but not for others: I guess my antenna models are wack : TBXLHB-6565A-VTM OR Kathrein - PR-950 OR RVVPX305.10R OR DBXLH-8585A-VTM I intended to just type say: 6565A and hopefully get TBXLHB-6565A-VTM or type DBXLH and get DBXLH-8585A-VTM. But nothing shows up. This is another question: Do you think there is a way for a list to be made so it could give suggestions as I type? since I would have 4 models for RVVPX305.10R XM R F and keeps changing for every model. how about if all my Mtexts are on layer Tx-0-TXT colour 30. Do you think there is a way to collect names then as I type create suggestions? Thanks Quote
pkenewell Posted December 5, 2019 Posted December 5, 2019 (edited) @Lee Mac NOTE: on MTEXT if the text is longer than 250 characters in the search, you would want to add in group code 3 as well. You would have to use the OR modifiers? Edited December 5, 2019 by pkenewell Quote
