I need a lisp where I can select multiple rectangles and run the command and select an offset distance and it will offset every rectangle and create a layer or add it to an existing layer that was made previously from the Autolisp
You missed one answer inside or outside ?  Must be plines not lines.
; Multi offsets of plines
; By AlanH DEC 2019
(defun c:moff (/ ANG CO-ORD DIST LAY OBJ OFF OLDSNAP PLENT PT1 PT2 PT3 SS X)
  (setq oldsnap (getvar 'osmode))
  (setq obj (vlax-ename->vla-object (car (entsel "\nPick object for layer "))))
  (setvar 'osmode 0)
  (setq lay (vla-get-layer obj))
  (setq ss (ssget (list (cons 0 "LWPOLYLINE") (cons 8 lay))))
  (setq off (getreal "\nEnter offset"))
  (if (/= ss nil)
        (setq plent (ssname ss (setq x (- x 1))))
        (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget plent))))
        (setq pt1 (nth 0 co-ord))
        (setq pt2 (nth 2 co-ord))
        (setq ang (angle pt1 pt2))
        (setq dist (/ (distance pt1 pt2) 2.0))
        (setq pt3 (polar pt1 ang dist))
        (command "offset" off plent pt3 "")
    (alert "No plines found")
  (setvar 'osmode oldsnap)
(c:moff)
Edited by BIGAL
