jammie Posted January 29, 2009 Posted January 29, 2009 Hi All, I have started experimenting with batch files and would like to start AutoCAD when I run a batch file. Is this possible? I have tried [color="RoyalBlue"]start[/color] "C:\Program Files\AutoCAD 2007\acad.exe" but this seems to only run another command prompt window Also could anyone recommend any links and resources on understaning batch files and maybe a beginners guide to DOS in general? Thanks Jammie Quote
dbroada Posted January 29, 2009 Posted January 29, 2009 if this is a batch file in the old DOS style, you don't need the "start" bit. Just the program path & name (don't need .exe either) will start the program. If you're not talking of that sort of batch file, sorry, please ignore me. Quote
jammie Posted January 29, 2009 Author Posted January 29, 2009 Hi dbroada That worked exactly the way I was hoping. I am hoping to create a simple batch file that I can run when I logon to my computer. One of the Senior Tech's was recalling the good old days of DOS based AutoCAD when he started working. Having no experience of the versions pre 2000 myself I guess I was curious to find out a little bit more about DOS and batch files Thanks for your help, Regards, -jammie Quote
ReMark Posted January 29, 2009 Posted January 29, 2009 If you like batch files (.bat) try your hand next at config files (.sys). Throw in some memory management parameters and have fun! Quote
jammie Posted January 30, 2009 Author Posted January 30, 2009 Thanks Remark, If you like batch files (.bat) try your hand next at config files (.sys). Throw in some memory management parameters and have fun! I am curious now, I think I will have to look into config files as well! Is there much of a difference between what you can achieve using a batch file or a config file? Regards Jammie Quote
jammie Posted January 30, 2009 Author Posted January 30, 2009 Thanks Eldon Watch out for the BUFFERS and RAMdisk I had actually had never heard of RAMdisks before! After doing a bit of research into RAMdisks they seem to act as a virtual drive for temporarily storing infomation. I suppose the more RAM the computer has the more efficently it can run with a RAMdisk. Looking for a bit more info on buffers I came across a useful link for DOS if anyone is interested http://www.easydos.com/dosindex.html Regards, Jammie Quote
BIGAL Posted February 2, 2009 Posted February 2, 2009 As your running some form of windows you should beable to add autocad to your Startup group which means it runs on power up. Search windows help or then net for startup. Quote
jammie Posted February 2, 2009 Author Posted February 2, 2009 As your running some form of windows you should beable to add autocad to your Startup group which means it runs on power up. Search windows help or then net for startup. That is very useful to know. By adding a shortcut to AutoCAD in the following directory it now starts up when the computer boots up C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup Thanks BIGAL! Quote
