barakar42 Posted December 16, 2019 Share Posted December 16, 2019 Hi, I currently have a single DWG file with multiple layouts on that have viewports into model space that relate to different systems. Would it be possible to use a list of drawing numbers from Excel to delete the layout tabs that aren't in that list? Or if I need to split the single DWG into multiple files with a single layout tab each, would it be possible to combine them all back into one file once I've deleted all the irrelevant ones? Chris Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted December 16, 2019 Share Posted December 16, 2019 If you can write Visual Basic, it should be easy enough to whip up some code to do this. Cycle through each layout, find the Excel entry for it, or delete it if not found. I don't think AutoLISP has the tools to access Excel, but who knows. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 16, 2019 Share Posted December 16, 2019 With Access, Word and Excel it will work both ways. for Excel you can have Autocad populate and read cells and no doubt lots more, like wise you can have excel do all the work using excel VBA. I don't think AutoLISP has the tools to access Excel, its very straight forward in Visual lisp to access excel and talk to it. have a look at Getexcel.lsp has lots of functions inside it. Like wise this sample excel vba will draw objects in Autocad. Sub Opendwg() Dim acadApp As Object Dim acadDoc As Object 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") If acadApp Is Nothing Then Set acadApp = CreateObject("AutoCAD.Application") acadApp.Visible = True End If 'Check (again) if there is an AutoCAD object. If acadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If On Error GoTo 0 'If there is no active drawing create a new one. On Error Resume Next Set acadDoc = acadApp.ActiveDocument If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add End If On Error GoTo 0 'Check if the active space is paper space and change it to model space. If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding End If End Sub Public Sub addline(x1, y1, z1, x2, y2, z2) ' Create the line in model space Dim acadApp As Object Dim acadDoc As Object Set acadApp = GetObject(, "AutoCAD.Application") Set acadDoc = acadApp.ActiveDocument Dim startpoint(0 To 2) As Double Dim endpoint(0 To 2) As Double Dim lineobj As Object startpoint(0) = x1: startpoint(1) = y1: startpoint(2) = z1 endpoint(0) = x2: endpoint(1) = y2: endpoint(2) = z2 Set lineobj = acadDoc.ModelSpace.addline(startpoint, endpoint) acadApp.ZoomExtents End Sub Public Sub addcirc(x1, y1, z1, rad) ' Create the circle in model space Dim acadApp As Object Dim acadDoc As Object Set acadApp = GetObject(, "AutoCAD.Application") Set acadDoc = acadApp.ActiveDocument Dim cenpoint(0 To 2) As Double Dim circobj As Object cenpoint(0) = x1: cenpoint(1) = y1: cenpoint(2) = z1 Set circobj = acadDoc.ModelSpace.addcircle(cenpoint, rad) acadApp.ZoomExtents End Sub Sub addpoly(cords, col) Dim acadApp As Object Dim acadDoc As Object Set acadApp = GetObject(, "AutoCAD.Application") Set acadDoc = acadApp.ActiveDocument Dim oPline As Object ' add pline to Modelspace Set oPline = acadDoc.ModelSpace.AddLightWeightPolyline(cords) oPline.Color = col End Sub Sub alan1() ' This example adds a line in model space ' Define the start and end points for the line px1 = 1 px2 = 5 py1 = 1 py2 = 5 pz1 = 0 pz2 = 0 Call addline(px1, py1, pz1, px2, py2, pz2) End Sub Sub alan2() px1 = 1 py1 = 1 pz1 = 0 Radius = 8.5 Call addcirc(px1, py1, pz1, Radius) End Sub Sub alan3() 'Dim coords(0 To n) As Double Dim coords(0 To 5) As Double coords(0) = -6: coords(1) = 1: coords(2) = 3: coords(3) = 5: coords(4) = 7.55: coords(5) = 6.25: col = 1 Call addpoly(coords, col) End Sub Quote Link to comment Share on other sites More sharing options...
barakar42 Posted December 19, 2019 Author Share Posted December 19, 2019 Thanks for that you two. I've had a play with VBA, and can get it to delete a tab. However I can't get it to delete certain tabs I have an excel sheet that compares two values and outputs a 1 or 0 depending if they match or not. The problem is trying to get a variable value into the command line. This is what i've come up with for checking for a 1 or 0 and deleting tabs: Sub delete_tabs() On Error Resume Next Dim acadCmd, match1num, match1 As String Dim range1, total As Range Dim I As Integer 'If Err.Description > vbNullString Then ' Err.Clear ' Set ACAD = CreateObject("AutoCAD.Application") 'End If total = Sheets(1).Range("A" & Rows.Count).End(xlUp).Row For I = 2 To total Set ACAD = GetObject(, "AutoCAD.Application") ACAD.Visible = True match1 = Sheets(1).Range("C" & I).Value match1num = Sheets(1).Range("B" & I).Value If match1 < 1 Then acadCmd = "-layout & d match1num " ACAD.ActiveDocument.SendCommand acadCmd & vbCr End If Next I Is there a way of getting the value for "match1num"s value into the command line? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 20, 2019 Share Posted December 20, 2019 Did not look at your code to deep but if you look at visual lisp examples you can get a layout list and then check is name in another list if not delete. This is similar method to VBA. (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for lay (vla-get-Layouts doc) (setq plotabs (cons (vla-get-name lay) plotabs)) ) (setq len (length plotabs)) Quote Link to comment Share on other sites More sharing options...
