John Miller Posted December 17, 2019 Share Posted December 17, 2019 I use inventor 19 pro. How to import .step file so I can unfold .12 sheet metal in Sheet metal in inventor. Quote Link to comment Share on other sites More sharing options...
John Miller Posted December 17, 2019 Author Share Posted December 17, 2019 I use inventor 19 pro. Have a step folded. Trying to use inventor to get a flat pattern . Quote Link to comment Share on other sites More sharing options...
Lazer Posted February 2, 2020 Share Posted February 2, 2020 You need to open the .step file >convert to sheetmetal. Then set the thickness to the same thickness as the step file, It should then unfold for you. Quote Link to comment Share on other sites More sharing options...
