Mechanical designer
I use inventor 19 pro. How to import .step file so I can unfold .12 sheet metal in
Sheet metal in inventor.
I use inventor 19 pro. Have a step folded. Trying to use inventor to get a flat pattern .
  • 1 month later...
You need to open the .step file >convert to sheetmetal. Then set the thickness to the same thickness as the step file, It should then unfold for you.
