Using SendCommand to pass a variable
I have a VBA macro that passes an argument to AutoCAD command line using the 'SendCommand' function as below;
ACAD.Visible = True
acadCmd = "-layout & d layout1"
ACAD.ActiveDocument.SendCommand acadCmd & vbCr
In this instance I can delete the layout tab 'layout1' however I would like to know if it is possible to pass a string variable as the argument.
I have an excel sheet with all the layout tab names that I want to delete, I then want to loop through this sheet and send the command to AutoCad to delete this tab, as below;
Sub delete_tabs()
On Error Resume Next
Dim acadCmd, match1name, match1 As String
Dim range1, total As Range
Dim I As Integer
If Err.Description > vbNullString Then
    Err.Clear
    Set ACAD = CreateObject("AutoCAD.Application")
End If
total = Sheets(1).Range("A" & Rows.Count).End(xlUp).Row
For I = 2 To total
    Set ACAD = GetObject(, "AutoCAD.Application")
    ACAD.Visible = True
    match1 = Sheets(1).Range("C" & I).Value
    match1name = Sheets(1).Range("B" & I).Value
        If match1 < 1 Then
            acadCmd = (-layout & d, match1num)
        End If
Next I
End Sub
I cannot find any documentation on this SendCommand function, is it possible to do what I want?
Thanks in advance!
Danny
Have a look at VBA concatetnate
try this not tested
acadCmd = "-layout" & " d " & layoutname
