FrankLeung Posted January 30, 2009 Posted January 30, 2009 Hello all, I just wonder if anyone have the same problem when exporting drawing to DWF in A3? My client required DWF format file. When I export those drawings, A1 are fine but not A3. When export A3 drawing, it chop both left and rigth hand side of the drawing. Will there any solution?? Frank Quote
BITDRAUGHTY Posted January 30, 2009 Posted January 30, 2009 are you using the publish command or just straight printing formthe dialogue box? Quote
ScribbleJ Posted January 30, 2009 Posted January 30, 2009 Check your Plot Area and Plot Scale parameters. If the plot area is by window check it to see if the window encompasses the entire sheet. If the scale is incorrect it will cut off the sheet. Quote
FrankLeung Posted February 1, 2009 Author Posted February 1, 2009 I am using Publish...and I checked all Plot area and Scale are correct Quote
