Anushka Posted January 3, 2020 Posted January 3, 2020 (edited) Hello guys, can anyone give me a hand? How do I edit the program to add a new viewport and crop and insert into the viewport the AutoCAD geolocation image. Image example! I tried to make some modifications to the code, but due to the little knowledge, I was unsuccessful! any help is good life. And thank you in advance !! ;;LINK ;;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/looking-for-a-lisp-routine-to-create-automulti-layouts-and/td-p/8539246 (defun GridsToLayouts ( UseUndoMarks / GridLayer GridAttribute SourceLayout TitleBlockHeight KeyZoomFactor TitleBlockName TitleBlockSheetNumberAttribute TitleBlockTotalSheetsAttribute vl-GetAttributeValue ss i enam edata grids grid id previd ssvp1 vp1 vpno1 ssvp2 vp2 vbno2 ptmin ptmax ) ;;;*SOME SETTINGS THAT CAN BE CUSTOMIZED (setq GridLayer "P_Prancha") (setq GridAttribute "NUMERO_PRANCHA") (setq SourceLayout "001") (setq TitleBlockHeight 80) (setq KeyZoomFactor 0.33) ;(setq TitleBlockName "XXX_2") ;(setq TitleBlockSheetNumberAttribute "SHEET_NO") ;(setq TitleBlockTotalSheetsAttribute "NO_OF_SHEETS") (defun vl-GetAttributeValue ( blk tag ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes) ) ) (cond ((not (setq ss (ssget "x" (list (cons 0 "INSERT") (cons 8 GridLayer))))) (princ (strcat "\nNo grid blocks on layer '" GridLayer "' found.")) ) ((not (member SourceLayout (layoutlist))) (princ (strcat "\nSource layout '" SourceLayout "' not found.")) ) ((> (length (layoutlist)) 1) (princ (strcat "\nOnly layouts 'Model' and '" SourceLayout "' should exist.")) ) (T (Vl-cmdf "_.IsolateObjects" ss "") (setq i 0) (while (< i (sslength ss)) (setq edata (entget (setq enam (ssname ss i)))) (if (and (= (cdr (assoc 0 edata)) "INSERT") (setq attval (vl-GetAttributeValue (vlax-ename->vla-object (cdr (assoc -1 edata))) GridAttribute)) ) (setq grids (cons (cons attval enam) grids)) ) (setq i (1+ i)) ) (setq grids (vl-sort grids (function (lambda (e1 e2) (< (car e1) (car e2)))))) (if UseUndoMarks (vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))) (if grids (princ "\nCreating layouts...") (princ "\nNo grids found...") ) (foreach grid grids (if grids (progn (setq id (car grid) enam (cdr grid)) (princ (strcat "\n layout '" id "'... ")) (if (not (member id (layoutlist))) (command "._layout" "c" previd id) ) (command "._layout" "s" id "._pspace") (if (and (setq ssvp1 (ssget "x" (list (cons 0 "VIEWPORT") (cons -4 "*,>,*") (list 10 0 TitleBlockHeight 0)))) (setq ssvp2 (ssget "x" (list (cons 0 "VIEWPORT") (cons -4 "*,<,*") (list 10 0 TitleBlockHeight 0)))) ;;>> I modified it here! (setq ssvp3 (ssget "x" (list (cons 0 "VIEWPORT") (cons -4 "*,<,*") (list 10 0 TitleBlockHeight 0)))) ;;------ ) (progn (vla-getboundingbox (vlax-ename->vla-object enam) 'ptmin 'ptmax) (setq vpno1 (cdr (assoc 69 (entget (setq vp1 (ssname ssvp1 0)))))) (setq vpno2 (cdr (assoc 69 (entget (setq vp2 (ssname ssvp2 0)))))) (setq vpno3 (cdr (assoc 69 (entget (setq vp3 (ssname ssvp3 0)))))) ;;I modified it here! (command "._mspace") (setvar "CVPORT" vpno1) (vla-zoomwindow (vlax-get-acad-object) ptmin ptmax) (setvar "CVPORT" vpno2) (vla-zoomwindow (vlax-get-acad-object) ptmin ptmax);; (setvar "CVPORT" vpno3) ;;I modified it here! (vla-zoomwindow (vlax-get-acad-object) ptmin ptmax);;I modified it here! (vla-zoomscaled (vlax-get-acad-object) KeyZoomFactor acZoomScaledRelative) (command "._pspace") (vla-zoomextents (vlax-get-acad-object)) ) (princ (strcat "\nUnable to find the two vieports needed for layout " id)) ) (setq previd id) (if (= (length (layoutlist)) 255) (progn (princ "\nMaximum number of layouts met.") (setq grids nil) ) ) (vla-eval (vlax-get-acad-object) "DoEvents") ) ) ) (princ "\... GridsToLayouts finished.") (if UseUndoMarks (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))) (vl-cmdf "_.UnIsolateObjects") ) ) ) (defun C:GridsToLayouts nil (GridsToLayouts T) (princ)) (C:GridsToLayouts) DrawingT.dwg Edited January 3, 2020 by Anushka Quote
hanhphuc Posted January 5, 2020 Posted January 5, 2020 perhaps after inserting image, crop using command: _IMAGECLIP Quote
