I have a routine that plots my sheet sets for home plans. The issue is there is a timer function in the program to *I think* pause the process to give time for the PDF to be created. The issue is the timer never functions properly and so I get my desired print but the program stalls. If I let it sit for 5-10 minutes I get the runtime error and the chance to debug.
But, I dont have that kind of time so I have to CTRL-ALT-DLT to close Acad and then load it back up. Is there any way to interrupt the function after the print is obtained? Like a cancel command? I cant figure out what is wrong with the code and I constantly need the print fucntion.
Any Ideers???
Comment out/delete the pauses in the code & see if it still works. The pauses may be a holdover needed for earlier versions.
The usual method to stop a lisp is the "esc" key.
If you are still stuck after Carl's suggestions - post the LISP and we'll take a look for ya :thumbsup:
Public Sub pauseTimer(PauseTime As Single)
'*** Timer for pausing during PDF printing for file copy from c:\pdftemp directory
Dim Start As Single
Start = Timer ' Set start time.
Do While Timer
DoEvents ' Yield to other processes
Loop
End Sub
This is where Debug takes me, I will post the whole thing in a minute
I may be talking out of my a*se but that looks like VBA instead of LISP
Right you are sir it is in VB, there are both on here and I must have mixed it up. I zipped the VB code and linked it, I have very little VB experience though, I can see what it is trying to do but dont understand why it gets stuck??
PlotCode.zip
Dim Start As Single
Do While Timer
Loop
End Sub
I would comment out the Do While part first. Some timer routines have problems these days as the processors are too fast for them and they get confused. DoEvents is a do nothing command that allows the processor to scan other parts of the computer rather than continuing with the job in hand. You can normally get VBA routines to stop with the Pause|Break key, possibly in conjunction with the shift or ctrl key.
To coment it out I just put *** before the line of code correct? Then I need to save the change and re-run to see if it affects it? I am not going to cause any issues with the code because I can just reverse it right?
EDIT I blocked off the whole timer section of code as well as the command under Public Sub where it refers ot he timer and it still printed and then froze and crashed the program after it prompted for the name of the file it was creating. It sat for about two minutes after and then crashed.
Just looking at the code, (and I know nothing about VB.. whatsoever) I would assume that you use ' for a comment - would I be right Dave?
Lee is correct - an apostrophe will comment out a line
if you are running this through the VBA editor in AutoCAD you can step through the code using the F8 key. You can also set breakpoint using the (I think) F9 key.
F9 is correct :)
Public Sub PDFCurrentBrochure()
'*** PDFs current 8.5 x 11 brochure
Dim sSeries As String, sPlanName As String, sFoundation As String, sVersion As String
Dim abSeries As String, abFoundation As String
Dim oPlot As AcadPlot
Dim plotLayouts(0) As String
Dim vLayoutList As Variant
Dim sLayout As String
Dim layoutsList(0) As String
Dim checkLayout As AcadLayout
Dim layoutFoundation As String, layoutSeries As String
Dim thisLayout As Variant
Dim checkBrochure As String
Dim MyData As DataObject
Dim finalPdfPath As String
Dim finalPdfFile As String
Dim finalPdfPathFile As String
Dim plotFileExt As String
Dim tempAcrobatPathFile As String
Dim tempPath As String
Dim paperSize As String
Dim pc3Current As String
On Error GoTo ErrorHandler
pc3Current = "Adobe PDF.pc3"
paperSize = "Letter"
tempPath = "c:\pdftemp"
Set oPlot = ThisDrawing.Plot
Set MyData = New DataObject
plotFileExt = "pdf"
finalPdfPath = ThisDrawing.Path
finalPdfPath = finalPdfPath + "\Brochures"
tempAcrobatPathFile = tempPath + "\" + ThisDrawing.Name
tempAcrobatPathFile = Replace(tempAcrobatPathFile, "dwg", plotFileExt)
tempAcrobatPathFile = Replace(tempAcrobatPathFile, "9.7", "9") ' Doug put a single quote ' in front of this entire line when I tell you
If Dir(finalPdfPath, vbDirectory) = "" Then
MkDir finalPdfPath
End If
sSeries = getDrawingProperty("currentSeries")
sPlanName = getDrawingProperty("propPlanName")
sFoundation = getDrawingProperty("currentFoundation")
sVersion = getDrawingProperty("propVersion")
abFoundation = getShortName(sFoundation)
abSeries = getShortName(sSeries)
For Each checkLayout In ThisDrawing.Layouts
checkBrochure = getLayoutPart(checkLayout.Name, 0)
If checkBrochure = "Bro" Then
layoutFoundation = getLayoutPart(checkLayout.Name, 1)
If layoutFoundation = abFoundation Then
layoutSeries = getLayoutPart(checkLayout.Name, 2)
If layoutSeries = abSeries Then
plotLayouts(0) = checkLayout.Name
checkLayout.CanonicalMediaName = GetCanonicalFromLocale(paperSize, pc3Current)
checkLayout.StyleSheet = "Brochure.ctb"
checkLayout.ConfigName = pc3Current
checkLayout.PlotRotation = ac0degrees
checkLayout.PlotType = acExtents
Exit For
End If
End If
End If
Next
If plotLayouts(0) "" Then
finalPdfFile = sSeries + "- " + sPlanName + "- " + sFoundation + "- " + sVersion + "- Brochure." + plotFileExt
finalPdfPathFile = finalPdfPath + "\" + finalPdfFile
If Dir(finalPdfPathFile, vbDirectory) "" Then
Kill finalPdfPathFile
End If
layoutsList(0) = CStr(plotLayouts(0))
vLayoutList = layoutsList
oPlot.SetLayoutsToPlot vLayoutList
oPlot.PlotToDevice pc3Current
While Dir(finalPdfPathFile, vbDirectory) = ""
Name tempAcrobatPathFile As finalPdfPathFile
Wend
If Dir(tempPath, vbDirectory) = "" Then
MkDir tempPath
ElseIf Dir(tempPath + "\*.pdf", vbDirectory) "" Then
Kill tempPath + "\*.*"
End If
End If
Exit Sub
ErrorHandler:
pauseTimer (1)
Resume Next
End Sub
So this is the code, what is the reason here at the end it runs this "pausetimer"?
Dim Start As Single
Do While Timer
Loop
End Sub
Here is the pause timer where the debug takes me too, it stops on the Do while timer line...
plotFileExt = "pdf"
MkDir finalPdfPath
End If
Exit For
End If
End If
End If
Next
End If
Wend
MkDir tempPath
End If
End If
Exit Sub
ErrorHandler:
pauseTimer (1)
Resume Next
End Sub
One question: Whos Doug? :P
Why not just comment out the whole error handler (eradicating the timer) and see what the error is that keeps taking you to the error handler in the first place.
Excuse my inexperience with VBA, but I tend to stutter... I mean LISP.
