; error: bad argument type: VLA-OBJECT nil
i have this lisp and i don't know wht it return bad argument nil if i select a block!
It put all on Layer 0  and set  lineweight on byblock
(defun LM:unique  (l) (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l))))))
(defun BB:setByBlock  (nam / blc blk)
  (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
  (setq blk (vla-item blc nam))
  (vlax-for x  blk (cond ( (= "0" (vlax-get-property x 'layer)) (vlax-put-property x 'lineweight acLnWtByBlock) (vlax-put-property x 'color 0))))
(vl-load-com)
(defun c:bf ( / c_doc sel cnt obj col)
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object)))
  (princ "\nSelect blocks : ")
  (setq sel (ssget '((0 . "INSERT"))))
  (cond (sel
          (repeat (setq cnt (sslength sel))
            (setq obj (vlax-ename->vla-object (ssname sel (setq cnt (1- cnt)))))
            (cond ( (= :vlax-true (vlax-get-property obj 'isdynamicblock))
                    (setq col (cons (vla-get-effectivename obj) col)
                          col (cons (vla-get-name obj) col)
                  (t  (setq col (cons (vla-get-effectiveName obx) col)))
            );end_cond
          );end_repeat
          (setq col (LM:unique col))
          (foreach x col (BB:setByBlock x))
        ( (princ "\nNothing Selected"))
  );end_cond
  (vla-regen c_doc acActiveViewport)
);end_defun
