Adding "if" command to only work if text at certain heights exists
Hi I created this lisp from parts of other lisps I found and it works fine to resize text that is height 8 and 6 to 0.2, however, it spits an error if there is no text in the drawing at 6 or 8mm.
Is anyone able to provide assistance as to how resolve this, I'm assuming I need to first check if text at each of these heights exists first but I can't find out how to do this.
(defun C:FIXTXT ()(vl-load-com)
(foreach ent (mapcar 'cadr (ssnamex (ssget "X" (list '(0 . "TEXT") (cons 40 6)))))
 (vla-put-height (vlax-ename->vla-object ent) 0.2))
(foreach ent (mapcar 'cadr (ssnamex (ssget "X" (list '(0 . "TEXT") (cons 40 8)))))
Thanks
Hi,
Welcome to the forum. :)
Try the following although it would be much better if you just used the DXF codes instead of converting each object to vla-object in this case but anyway that works as well.
(defun C:FIXTXT (/ ss)
  (if (setq ss (ssget "X" '((0 . "TEXT") (-4 . "<OR") (40 . 6) (40 . 8) (-4 . "OR>"))))
    (foreach ent (mapcar 'cadr (ssnamex ss))
) (vl-load-com)
  • 1 month later...
Thanks for the help, works perfectly.
You're welcome anytime.
