[HELP] ssget to select all dimensions less than a number.
haisagiviz
Hi everyone,
I can make select all dimension = 0 to delete as below code
(setq ss5 (ssget "X2" '((0 . "DIMENSION") (42 . 0.0))))
(command "erase" ss5 "")
But I don't know why it is not working sometime. Is there anyway to filter the dimensions which less than a number (<0.1) like quick select tool.
Thank you.
10 hours ago, hanhphuc said:
(sssetfirst nil (ssget "_X" '((0 . "DIMENSION")(-4 . "<") (42 . 0.1)) ) )
for more info here -->  logical operators
It is exactly what I want to do.
Thank you so so much for help and more info.
Edited by haisagiviz
Can you help me is there anyway to detect dimension's node when its distance from dimension line are greater than a number and move them back to dimension base line.
Because my drawing problem is: the dimension's extend line is overlap with other line such as grid, wall line...
Thanks again.
P/S: @hanhphuc are you from Vietnam?
