mousho Posted February 6, 2020 Posted February 6, 2020 HELLO ALL Im trying to figuare how can i get point coordinate by field?? the next step is to add it to exist lisp that Edwin Prakoso wrote https://www.cad-notes.com/using-autolisp-to-label-point-coordinate/ thx to all Quote
BIGAL Posted February 7, 2020 Posted February 7, 2020 It is a bit more complex but a field can get X Y & Z of a point just go into mtext and use the field option and look at the expression created need to do 3 times. Can then use this method in a lisp. Need Lee-mac object id lisp. Just google answer should be out there all done. Quote
mousho Posted February 9, 2020 Author Posted February 9, 2020 hi bigal i search all the web with no sucess Quote
tombu Posted February 9, 2020 Posted February 9, 2020 I use a block insertion ;| Label for Point. PtLabel.lsp BY: TOM BEAUFORD ^P(or C:Label (load "PtLabel.lsp"));PtLabel BeaufordT@LeonCountyFL.gov Leon County Public Works/Engineering ==================================================================|; (defun C:PtLabel (/ ATTDIA) (setq ATTDIA (getvar "ATTDIA")) (setvar "ATTDIA" 0) (command "._INSERT" "Pt_Coordinates" (getpoint "Pick Point: ") ;Insert pt (/ 0.1 (getvar "cannoscalevalue")) ;X Scale ; (* (getvar "DIMTXT") (getvar "DIMSCALE")) ;X Scale (Alternate) "" ;Y Scale ; "" ;Rotation (*(/(getvar "viewtwist")pi)-180) ;Rotation "" ;Easting "" ;Northing ) (setvar "ATTDIA" ATTDIA) (entupd (entlast)) ; (command "._DDATTE" (entlast)) (princ) ) I use the same concept when labeling elevations. Google "label coordinates AutoCAD Lisp", doesn't appear you searched the web very hard. Pt_Coordinates.dwg Quote
mousho Posted February 10, 2020 Author Posted February 10, 2020 thx tombu it was very helpful and im sure that im going to add it to my lisp routine, but im looking for lisp that not using block i find this lisp in the web and it more closer to what im looking, the lisp here add automatically coord at each vertex i want the option to add coord at free choose any idea?? ptdef-xyz_field.lsp Quote
mousho Posted February 10, 2020 Author Posted February 10, 2020 8 hours ago, BIGAL said: Have a look at this BIGAL THX BUT I HAVE NO IDEA HOW TO USE IT AT LISP Quote
