mousho Posted February 6, 2020 Share Posted February 6, 2020 HELLO ALL Im trying to figuare how can i get point coordinate by field?? the next step is to add it to exist lisp that Edwin Prakoso wrote https://www.cad-notes.com/using-autolisp-to-label-point-coordinate/ thx to all Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 7, 2020 Share Posted February 7, 2020 It is a bit more complex but a field can get X Y & Z of a point just go into mtext and use the field option and look at the expression created need to do 3 times. Can then use this method in a lisp. Need Lee-mac object id lisp. Just google answer should be out there all done. Quote Link to comment Share on other sites More sharing options...
mousho Posted February 9, 2020 Author Share Posted February 9, 2020 hi bigal i search all the web with no sucess Quote Link to comment Share on other sites More sharing options...
tombu Posted February 9, 2020 Share Posted February 9, 2020 I use a block insertion ;| Label for Point. PtLabel.lsp BY: TOM BEAUFORD ^P(or C:Label (load "PtLabel.lsp"));PtLabel BeaufordT@LeonCountyFL.gov Leon County Public Works/Engineering ==================================================================|; (defun C:PtLabel (/ ATTDIA) (setq ATTDIA (getvar "ATTDIA")) (setvar "ATTDIA" 0) (command "._INSERT" "Pt_Coordinates" (getpoint "Pick Point: ") ;Insert pt (/ 0.1 (getvar "cannoscalevalue")) ;X Scale ; (* (getvar "DIMTXT") (getvar "DIMSCALE")) ;X Scale (Alternate) "" ;Y Scale ; "" ;Rotation (*(/(getvar "viewtwist")pi)-180) ;Rotation "" ;Easting "" ;Northing ) (setvar "ATTDIA" ATTDIA) (entupd (entlast)) ; (command "._DDATTE" (entlast)) (princ) ) I use the same concept when labeling elevations. Google "label coordinates AutoCAD Lisp", doesn't appear you searched the web very hard. Pt_Coordinates.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 10, 2020 Share Posted February 10, 2020 Have a look at this Quote Link to comment Share on other sites More sharing options...
mousho Posted February 10, 2020 Author Share Posted February 10, 2020 thx tombu it was very helpful and im sure that im going to add it to my lisp routine, but im looking for lisp that not using block i find this lisp in the web and it more closer to what im looking, the lisp here add automatically coord at each vertex i want the option to add coord at free choose any idea?? ptdef-xyz_field.lsp Quote Link to comment Share on other sites More sharing options...
mousho Posted February 10, 2020 Author Share Posted February 10, 2020 8 hours ago, BIGAL said: Have a look at this BIGAL THX BUT I HAVE NO IDEA HOW TO USE IT AT LISP Quote Link to comment Share on other sites More sharing options...
mousho Posted February 11, 2020 Author Share Posted February 11, 2020 THX TO ALL FIND SOLUTION Quote Link to comment Share on other sites More sharing options...
