gS7 Posted February 16, 2020 Posted February 16, 2020 Hi Guys, I need a Help here i have created a autolisp for insert Blocks , in this i am showing invalid layers for user I.e block not available for that layers. But my problems is if same layer found more then one it will repeat for all same layers i don't want to show error for every same layers. Please help me  (defun c:parkingblock(/ addblock ss acaddocument space i snm lnm pos) (vl-load-com) (defun addblock (sp pos nm lname en / b) (setq b (vla-insertblock sp pos nm 0.1 0.1 0.1 0.0)) (vla-put-layer b lname) (vla-delete en) ) (if (setq ss (ssget '((0 . "POINT")))) (progn (setq acadDocument (vla-get-activedocument (vlax-get-acad-object))) (setq space (vla-get-modelspace acadDocument)) (repeat (setq i (sslength ss)) (setq snm (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (setq lnm (vlax-get snm 'layer)) (setq pos (vla-get-Coordinates snm)) (cond ((= lnm "P_SEM_P") (addblock space pos "937" "P_SEM_P" snm)) ((= lnm "P_ILL_P") (addblock space pos "950" "P_ILL_P" snm)) ((= lnm "ALB_P") (addblock space pos "968" "ALB_P" snm)) ((= lnm "P_TEL_P") (addblock space pos "980" "P_TEL_P" snm)) ((= lnm "ZSD_P") (addblock space pos "953" "ZSD_P" snm)) ((= lnm "DIS_SOST") (addblock space pos "926" "DIS_SOST" snm)) (t (princ (strcat "\nBlock not found for Layer: " lnm)));; Problem ) ) ) ) (princ)) Regards, Ganesh Quote
dlanorh Posted February 16, 2020 Posted February 16, 2020 (edited) 53 minutes ago, gS7 said: Hi Guys, I need a Help here i have created a autolisp for insert Blocks , in this i am showing invalid layers for user I.e block not available for that layers. But my problems is if same layer found more then one it will repeat for all same layers i don't want to show error for every same layers. Please help me  (defun c:parkingblock(/ addblock ss acaddocument space i snm lnm pos) (vl-load-com) (defun addblock (sp pos nm lname en / b) (setq b (vla-insertblock sp pos nm 0.1 0.1 0.1 0.0)) (vla-put-layer b lname) (vla-delete en) ) (if (setq ss (ssget '((0 . "POINT")))) (progn (setq acadDocument (vla-get-activedocument (vlax-get-acad-object))) (setq space (vla-get-modelspace acadDocument)) (repeat (setq i (sslength ss)) (setq snm (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (setq lnm (vlax-get snm 'layer)) (setq pos (vla-get-Coordinates snm)) (cond ((= lnm "P_SEM_P") (addblock space pos "937" "P_SEM_P" snm)) ((= lnm "P_ILL_P") (addblock space pos "950" "P_ILL_P" snm)) ((= lnm "ALB_P") (addblock space pos "968" "ALB_P" snm)) ((= lnm "P_TEL_P") (addblock space pos "980" "P_TEL_P" snm)) ((= lnm "ZSD_P") (addblock space pos "953" "ZSD_P" snm)) ((= lnm "DIS_SOST") (addblock space pos "926" "DIS_SOST" snm)) (t (princ (strcat "\nBlock not found for Layer: " lnm)));; Problem ) ) ) ) (princ)) Regards, Ganesh  Perhaps your layer names are not all upper case! When using the (=) function "Defpoints" does not = "DEFPOINTS" so you should test like this  (= (strcase lnm) "P_SEM_P") ;or change this (setq lnm (vlax-get snm 'layer)) ;; to (setq lnm (strcase (vlax-get snm 'layer)))    Edited February 16, 2020 by dlanorh Quote
gS7 Posted February 17, 2020 Author Posted February 17, 2020 Hi Dlanorh ,  I think you did not get my point. It will repeat same layer names like this. If same layer for more then one i want to show them only one time to user  Example : Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P Block not found for Layer: COL_EL  Block not found for Layer: M_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: RBPA_A Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: COL_EL Block not found for Layer: COL_EL Block not found for Layer: COL_EL Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: P_SEG_P Block not found for Layer: M_SEG_P  Quote
BIGAL Posted February 17, 2020 Posted February 17, 2020 (edited) You need some sort of flag list ("P_SEG_P" "yes") so if its yes don't display else change ("P_SEG_P" "No") to yes. You will need to make the list before hand of all the corresponding layers make it a defun saves lots of code in main routine and you can test separately as it will need a repeat for the length of the list. Plus a double nth or car & cadr  (("P_SEG_P" "No")("M_SEG_P" "No")(COL_…….) (t (princ (strcat "\nBlock not found for Layer: " lnm)));; Problem  Edited February 17, 2020 by BIGAL Quote
Roy_043 Posted February 17, 2020 Posted February 17, 2020 Untested (no sample DWG) but something like this should work: (defun c:parkingblock(/ addblock ss acaddocument space i snm lnm pos missingLyrLst) (vl-load-com) (defun addblock (sp pos nm lname en / b) (setq b (vla-insertblock sp pos nm 0.1 0.1 0.1 0.0)) (vla-put-layer b lname) (vla-delete en) ) (if (setq ss (ssget '((0 . "POINT")))) (progn (setq acadDocument (vla-get-activedocument (vlax-get-acad-object))) (setq space (vla-get-modelspace acadDocument)) (repeat (setq i (sslength ss)) (setq snm (vlax-ename->vla-object (ssname ss (setq i (1- i))))) (setq lnm (vlax-get snm 'layer)) (setq pos (vla-get-Coordinates snm)) (cond ((vl-position lnm missingLyrLst) nil ) ((= lnm "P_SEM_P") (addblock space pos "937" "P_SEM_P" snm) ) ((= lnm "P_ILL_P") (addblock space pos "950" "P_ILL_P" snm) ) ((= lnm "ALB_P") (addblock space pos "968" "ALB_P" snm) ) ((= lnm "P_TEL_P") (addblock space pos "980" "P_TEL_P" snm) ) ((= lnm "ZSD_P") (addblock space pos "953" "ZSD_P" snm) ) ((= lnm "DIS_SOST") (addblock space pos "926" "DIS_SOST" snm) ) (t (setq missingLyrLst (cons lnm missingLyrLst)) (princ (strcat "\nBlock not found for Layer: " lnm)) ) ) ) ) ) (princ) ) Â Quote
gS7 Posted February 17, 2020 Author Posted February 17, 2020 Thank you Bigal for your suggestion . and Roy_043 It is working like charm thank you for your codes. Quote
