Is there anyone who can help me?
When I use the wblock command in Autolisp, I want to be able to choose where to save the block. This is necessary to be able to record in a different place each time I use it.
Thanks in advance.
This works fine for me, using 2019, as long as "c:\myfolder" exists.
(vl-cmdf "._wblock" "C:/myfolder/output.dwg" "*")
thank you rkmcswain but I something wrong
1- I don't need all objects so I need basepoint and selection set
2- the saving path have to be able to change so I need path window for choose path
(defun c:ww() (command "wblock" ))
now when I run this code acad want a filename if I just put the enter  acad opening windows explorer to find a file for save. after that acad wants a base point and after that wants selected objects.
How can I make this steps in lisp like code below.
Quote
(defun c:ww ()
(setq pt (getpoint "BasePoint")
          ss (ssget))
(command "wblock" "" pt ss)
