Good morning to everyone, they would be so kind to support me with a routine that eliminates leader and converts them into texts. thank you very much for your attention. Attached example file. thanks
MLTOTEXT.dwg
5 minutes ago, ronjonp said:
Explode? Why are you doing this?
I usually explore it when I have only one multileader, but if I have 100 or more multileader it is very tedious to delete the leaders of each one of them
Code is not really needed but this will get your selection at least
(defun c:foo (/ s)
  (if (setq s (ssget ":L" '((0 . "MULTILEADER"))))
    (sssetfirst nil s)
Then in the properties palette:
Edited by ronjonp
Try this.
(vl-load-com)
(defun C:TxtMLeader (/ CDR10 CMD ENT LS_ENT)
 (defun CDR10 (EntData / list10)
  (foreach el EntData
   (if (= (car el) 10)
    (setq list10 (cons (cdr el) list10))
  list10
 ) ;;CDR10
 (while
  (setq ENT (car (entsel "\nSelect MLeader entity: ")))
  (if (and
     (= (cdr (assoc 0 (entget ENT))) "MULTILEADER")
     (not (vl-position ENT LS_ENT))
    (vla-highlight (vlax-ename->vla-object ENT) :vlax-true)
    (setq LS_ENT (cons ENT LS_ENT))
    (prompt (strcat "\n" (itoa (length LS_ENT)) " found"))
 (prompt
  (if LS_ENT
    (setq CMD (getvar "CMDECHO"))
    (setvar "CMDECHO" 0)
    (vl-cmdf "_.UNDO" "_Mark")
    (mapcar
     (function
      (lambda (x / ls_pts)
       (setq ls_pts (CDR10 (entget x)))
       (vl-cmdf "_.EXPLODE" x)
       (mapcar
        (function
         (lambda (y / e)
          (if (and
             (setq e (ssget y))
             (not (vl-position (cdr (assoc 0 (entget (ssname e 0)))) (quote ("TEXT" "MTEXT" "INSERT"))))
           (setq e (command "_.ERASE" e ""))
        ls_pts
     LS_ENT
    (vl-cmdf "_.UNDO" "_End")
    (setvar "CMDECHO" CMD)
    (strcat "\n" (itoa (length LS_ENT)) " MultiLeader entities modified")
   "\nNorthing selected."
