send field expression to autocad from excel vba
I have an excel file in which, i have a data in cell A like "dia of circle" , and using a formula in cell B i calculate area of circle for e.g 22/7*(value of cell A /2)^2 , then in cell C , i use a concatenate command to combine values in cell A and cell B , then using vba i plot this text on autocad like "dia of 2 = 3.14" , but now i need to change its dia for which area should be calculate , i heard that autocad have insert field command by which it do calculation , but problems comes when i have to give objid , like i want to put formula in field 22/7*(text value /2 )^2 , here text value is the object that i have to select it manually , is there is way in vba  , that i added a text "2" , then add another text in which field expression is used containing previous text reference
Here is a lisp that returns object id you can rewrite into VBA it probably exists already just google, for the vl object part you can use the (entlast) as you are using excel to create circle.
; Thanks to Lee-mac
(defun LM:acdoc nil
   (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
   (LM:acdoc)
(defun LM:objectid ( obj )
   (eval
       (list 'defun 'LM:objectid '( obj )
           (if (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
               (if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
                   (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
                  '(LM:ename->objectid (vlax-vla-object->ename obj))
              '(itoa (vla-get-objectid obj))
   (LM:objectid obj)
Why not use PI()? e.g.:
=PI()*(A1/2)^2
  • 1 month later...
if i want to insert field formula in auto cad, through excel , how can i do this , i don' want to use lisp , all my data is in excel form , if i want to draw a circle i simply type "c 0,0 d 10" then i copied it and paste to command line and circle is drawn , for multiple command i use excel vba to send it to auto cad , all i want is to write an expression for field that contain formula , then i copied and paste it to command line , to  achieve my desire results
i found some useful stuff on youtube
You missed out the LM:ename->objectid function. Pretty sure it would yield an error "No function definition: LM:ename->objectid", though I haven't tried it on myself.
