Hey everyone.  I'm trying to build a Dynamic Block that is comprised of other Dynamic Blocks.  I've never done this before and having a hard time finding a straight answer as to whether or not it's even possible.  The goal is to have one Super Ultra Mega Dynamic Block that can be inserted, and from that I can go thru the varying points of it and make changes, ie; select pipe size, flange size, change tags, etc.  Thanks for the help.
A block in a block wont wont with the dynamics.
What you can do, is make various 'Visibility States' and assign synmics to each state.
Sounds like you want a properties table which can combine various dynamic parameters into a simple table, it's just not simple to explain 😀. But no you cannot nest dynamic blocks and access the 'inner' blocks dynamic properties.
Think i'm following everything you're all saying.  Time for some experiments.  Thanks for the help.
