so i used a different lisp to get the length and width of a certain number of rectangles and it got me a nice table with the both of them very nicely filled in it. however the numbers are 12.8348 and 15.2848. i did change the decimal settings and got them to 12.83 and 15.28.
here i actually just want them to be rounded off to 5 like 12.85 and 15.30. i cant seem to do that, id be grateful if anything could help me in rounding them off.
p.s. is there just any lisp that gives me all three(length, width and area of a selected rectangle)?
any help and advice would be helpful. thanks.
refer image
Hello Mayur97 and welcome in the forum!
If you already used a Lisp to create the table, I think the simplest approach would be to adjust that Lisp to give you what you need. Post the code if possible and for sure someone will jump in to help you
You can use a rounding function such as:
(defun roundm ( x m )
    (* m (atof (rtos (/ x (float m)) 2 0)))
_$ (roundm 15.2848 0.05)
15.3
_$ (roundm 12.8348 0.05)
12.85
And then convert the result to a string using rtos, e.g.:
_$ (rtos (roundm 15.2848 0.05) 2 2)
"15.30"
_$ (rtos (roundm 12.8348 0.05) 2 2)
"12.85"
Being a rectang you will have 4 vertices, so length is distance v1-v2 and width v2-v3. So use co-ords to work out lengths only problem is which is length and width due to start point. But you can check angle for Hor and Vert.
(setq plent (entsel "\nPick rectang"))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
(alert (Strcat "Length is " (rtos (abs (distance (nth 0 co-ord)(nth 1 co-ord))) 2 2) "\nWidth is " (rtos (abs (distance (nth 1 co-ord)(nth 2 co-ord))) 2 2)))
hi, thanks but since i used a lisp to create the table i can only set it to the limit where i can change the decimal values to just two digits. ill have the lisp i used attached with the text here. thank you.
Count rectangle dims.LSP
15.3
12.85
"15.30"
"12.85"
I'm sorry i am not aware of how to do that(converting to a string using rtos). thank you for the helpful reply though.
i am not much familiar with coding yet.
I'm still very new to the software, and just learned how to create a lisp using the codes. But i am not aware of how do I use the codes that you shared here. I'm thankful for the reply and will look further into this.
Oh, I see!
Mayur97, I suggest you to write a private message to Stefan BMR and kindle ask him to have a look on this thread.
