The attached Dynamic Block is a RFWN Flange with mating RF Flange.  It has a tag across the center of it.  This tag will ordinarily be replaced with a more detailed company tag but there's a temporary one there for the sake of asking questions.  The current Visibility States are 2" 150# - 2" 2500#.  I'm trying to see if it's possible to make it so that the Tag is also able to switch Visibility between Tag Number1 and Tag Number 2 (currently off to the side).  This way once I make my flange size selection, I can select which tag I want to use.  Does anyone know how to go about doing that?  Would Greatly appreciate the help.  Tks.
Dyn_Flg.dwg
once more, with feeling....
