alijahed Posted February 1, 2009 Posted February 1, 2009 Hi All, Is there any chance to have different base points for one block which gives me opportunity to put it in different places in regards to different objects? Cheers Ali Quote
ReMark Posted February 1, 2009 Posted February 1, 2009 Won't a dynamic block give you the option to set multiple insertion points and to cycle through them? Quote
alijahed Posted February 1, 2009 Author Posted February 1, 2009 If there is an option I have no idea:cry: can you please tell me? Cheers Won't a dynamic block give you the option to set multiple insertion points and to cycle through them? Quote
ReMark Posted February 1, 2009 Posted February 1, 2009 How about if I just point you towards a tutorial? http://www.dailyautocad.com/autocad/using-multiple-insertion-points-in-dynamic-blocks/ Quote
ReMark Posted February 1, 2009 Posted February 1, 2009 Here's another explanation on how to set up multiple insertion points: http://www.thecadgeek.com/blog/2009/01/05/creating-using-blocks-with-multiple-insertion-points/ Quote
ReMark Posted February 1, 2009 Posted February 1, 2009 Dynamic Block Tip by Heidi Hewitt. Re: Cycle Order: http://heidihewett.blogs.com/my_weblog/dynamic_blocks/ OK. Three different articles about the same topic from three different authors. That should give you plenty to read and practice with. Good luck. Quote
alijahed Posted February 1, 2009 Author Posted February 1, 2009 Hey mate those r fantastic I am pretty sure I'll find my answer in them and also learn more. many thanks as always Dynamic Block Tip by Heidi Hewitt. Re: Cycle Order: http://heidihewett.blogs.com/my_weblog/dynamic_blocks/ OK. Three different articles about the same topic from three different authors. That should give you plenty to read and practice with. Good luck. Quote
ReMark Posted February 1, 2009 Posted February 1, 2009 You're entirely welcomed, alijahed. When you're done you'll be able to help others and you can come back and teach me! Quote
