Hello all,
I am in need of some help. I am trying to create a dialog box that will help with processing multiple drawing files. I want to be able to add and remove from a list displayed in the dialog box as necassary. I guess it would be similar to a batch plot dialog, where I need to be able to search the typical windows directory structure in order to add files. I know this is pretty difficult, and not wise to do in Lisp, but I am not familiar with other languages yet. Do you know of any way to do this relatively easily, or resources that explain how to do it.
Thanks in advance
Geez Lee,
This "plot drawings" lisp is WAY over my head. I cant even figure out how the dialog box is set up, in order to learn from it. :D
...any less complex examples?
That was the first that came to mind ~ some of the LISPs on that site are mind-numbing...
Like, take a look at "TROY" on that link... :shock::shock: :shock::shock:
thats just plain insane. I couldn't even imagine drawings one asteroid stationary in lisp, let alone making a game out of it!
I did however just find these links:
http://www.kxcad.net/autodesk/autocad/AutoLISP_Reference_Guide/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-6a04.htm
http://www.simplecad.com/lisp/lispfile.htm
the file "bp.lsp" brings up a similar file search dialog, now i just need to figure out how to decypher the code. :roll:
Well, getfiled is a good function to use -
make sure you understand the differences in the bit-codes :)
