Hi Everyone,
I have a Lisp file to create a Layout, i given the Template file with full path, but while running it's taking another template by default.
When i trying in VLISP console it was working Perfectly and it takes correct Template. but when i trying with .lsp file I got the above issue. In the LSP file i have used the same script for A1, A2 and A3.
Please help me anyone to sort out this issue.
(defun c:A3()
(vl-load-com)
(command ".undo" "m")
(vlax-for layout (vla-get-layouts
(vla-get-ActiveDocument (vlax-get-acad-object))
(if (/= (vla-get-name layout) "Model")
(vla-delete layout)
(setq sht_nos '() sht_no "") (command "tilemode" "1")
(setq ss (ssget "X" '((2 . "A3") (66 . 1))))
(setq no_of_blocks(sslength ss))
(setq test 0)
(while (< test no_of_blocks)
(setq ent(ssname SS test))
(setq enx (entget (setq blk (entnext ent))))
;(print (item 1 enx))
(Setq entp(entget ent))
;(foreach a entp(print a))
(setq inspoint (item 10 entp))
(setq sht_no (item 1 enx))
(if (/= sht_no "-")
(command "-view" "w" sht_no inspoint "@396.0000,204.6493")
(setq sht_nos(append sht_nos (list sht_no)))
);progn
(print (type sht_no))
;(print inspoint)(print vname)
(setq test (1+ test))
);while
(terpri)
(setq sorted_sname_list(VL-SORT sht_nos '<))
(plott sorted_sname_list)
);defun DDP
(Defun ITEM (N E) (CDR (Assoc N E)))
(defun plott(shts)
(setq index 0)
(repeat (length shts)
(command "_layout" "template" "//net.ats/data/AutoCAD Tools/Tools/Template/TBTemplate.dwt" "A3")
(command "_layout" "set" "A3")
(command "_layout" "rename" "A3" (strcat "A" (nth index shts)  ""))
(command "layout" "set" (strcat "A" (nth index shts) ""))
(command "mspace" "-view" "r" (nth index shts) )(command "pspace")
(command "-view" "d" (nth index shts))
(command "-vports" "L" "ON" "all" "")
 (setq index(+ 1 index))
Thanks in Advance.
Hi Everyone,
Please anyone suggest/help me solve this issue.
A couple of possibility don't have directories so a little hard to check
When I test something like this I just copy and paste a few lines at a time and look at what went wrong.
The ss ssget may need (0 . "INSERT") also so gets blocks.
View (list 396.0000,204.65)
"//net.ats/data/AutoCAD Tools/Tools/Template/TBTemplate.dwt" its a known problem spaces in directory need \\ rather than / so server is \\\\
The other thing is as its a layout why are you using a template would not Insert a dwg title block do the same ?
