just a wild thought :
Is it possible to create layers based on the selected texts?
If the layer exist, skip. if it does not create it.
Example i have selected multiple text/mtext
Quote
TEST-01
TEST-03
TEST-03
TEST-04
TEST-05
I need to assign a prefix and suffix as per the company's standard layering format
Quote
prefix : A-_
suffix : -N
Final Layer name outcome :
Quote
A-_TEST01-N
A-_TEST02-N
A-_TEST03-N
A-_TEST04-N
A-_TEST05-N
Did you do any sort of google or search here for "does layer exist" its all out there, hint  (tblobjname "layer" lname),  the text string again hint "Get text string". oh don't forget (strcat good time to learn.
I have this routine which creates the XREF layer.
Can this be edited to achieve the above query?
(defun c:Xlay (/ cmd1)
(setq cmd1 (getvar 'cmdecho))
(setvar 'cmdecho 0)
(if
  (not
     (tblsearch "LAYER" "XREF")
  (command "-layer" "new" "XREF" "C" "7" "XREF" "")
(command "-layer" "set" "XREF" "")
(setvar 'cmdecho cmd1)
(print "XREF Layer now created and made current! ")
This in conjunction with what you have (tblobjname "layer" lname) just try it with a known and unknown lname.
Two more things to consider.
1st Use arguments in your lisp for layer name:
(defun PreLaySuf (Lay / cmd1)
	      Lay (strcat "A-_" Lay "-N")
so that one lisp could be used in a macro for any layer:
(PreLaySuf "TEST01")
(PreLaySuf "TEST02")
2nd If these layers already exist in a drawing or template use Lee Mac's http://www.lee-mac.com/steal.html to insert that list of layers into your drawing with something like:
(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt")
(list (list "layers" (list "A-_TEST01-N" "A-_TEST02-N" "A-_TEST03-N" "A-_TEST04-N" "A-_TEST05-N"))))
Try following code :
(defun layer (name)
  (entmake (list
	     '(0 . "LAYER")
	     (cons 100 "AcDbSymbolTableRecord")
	     (cons 100 "AcDbLayerTableRecord")
	     (cons 2 name)
	     (cons 70 0)
	     (cons 62 7)
	     (cons 6 "Continuous")
(setq p "A-_")
(setq s "-N")
(foreach x '("TEST-01" "TEST-02" "TEST-03" "TEST-04" "TEST-05")
  (if (not (tblsearch "layer" x))
    (layer (strcat p x s))
Edited by satishrajdev
(defun layer (name)
  (entmake (list
	     '(0 . "LAYER")
	     (cons 2 name)
	     (cons 70 0)
	     (cons 62 7)
(setq p "A-_")
(setq s "-N")
Thanks for this.
Edited by nod684
(defun c:test (/ ss i p s en Text)
  (setq ss (ssget '((0 . "Text"))))
  (setq i 0)
  (setq p "A-_")
  (setq s "-N")
  (repeat (sslength ss)
    (setq en   (ssname ss i)
	  Text (get_dxf en 1)
	  i    (1+ i)
  (entmake (list
	     '(0 . "LAYER")
	     (cons 2 (strcat p Text s))
	     (cons 70 0)
	     (cons 62 7)
(defun get_dxf (en num /)
  (cdr (assoc num (entget en)))
Try following code
Now you have the answer this is what I would use (chklay1 lay) that's it 1 line as the defun chklay is in my autoloaded library lisp. So chklay is available for every lisp I write. (chklay2 lay col lt)
  (setq i 0)
  (setq p "A-_")
  (setq s "-N")
	  Text (get_dxf en 1)
	  i    (1+ i)
  (entmake (list
	     '(0 . "LAYER")
	     (cons 70 0)
	     (cons 62 7)
Try following code
Hi Thanks, tried this but it did not create any layer after selecting multiple text...
perhaps TEXT string invalid for symbol table? or formatted MTEXT?
example:
<TEST-00
TEST-01>
TEST:02
TEST 03*10
TEST 04,05
TEST-05?
TEST=06
TEST|07
TEST-08/08
TEST-09\\P10
use snvalid to validate
(defun c:tt (/ $ ok str doc lays ss)
  (and (ssget "_:L" '((0 . "*TEXT")))
    (vlax-for obj (setq doc  (vla-get-ActiveDocument (vlax-get-acad-object)) lays (vla-get-layers (vla-get-Database doc ))
      					ss (vla-get-ActiveSelectionSet doc))
      (setq str	(vla-get-TextString obj) $ str )
      (if (and
	    (setq ok (snvalid str))
	    (not (tblsearch "LAYER" str))
	    (not (tblsearch "LAYER" (setq $ (strcat "A-_" str "-N"))))
	(progn (vla-add lays $)
	       (princ (strcat "\nNew layer created : " $))
	(princ (if (not ok)
		 "\nInvalid name! "
		 (strcat "\nLayer exists : " $)
      (progn (vla-put-layer obj $) (vla-put-color obj AcRed) ); change to new layer
  (vl-catch-all-apply 'vlax-release-object (list ss))
Edited by hanhphuc
release object, vla-put-color
  • Thanks 1
example:
<TEST-00
TEST-01>
TEST:02
TEST 03*10
TEST 04,05
TEST-05?
TEST=06
TEST|07
TEST-08/08
TEST-09\\P10
(defun c:tt (/ $ ok str doc lays)
    (vlax-for obj (vla-get-ActiveSelectionSet doc)
      (if (and
	(princ (if (not ok)
		 "\nInvalid name! "
      (if ok (vla-put-layer obj $)) ; change to new layer
Thanks! this one worked!
Just need now to manually assign the color.
Don't know if this can be integrated with the routine as well.
example :
(vla-put-color obj AcRed) ; or index 1
updated with progn
Edited by hanhphuc
1 hour ago, hanhphuc said:
example :
updated with progn
I don't know how to put. i have attached the image.
can it determine the color of the selected object and assign it to a layer?
Say, i select TEST-01 and color red, then TEST-02 its corresponding color...
LEGEND.dwg
Edited by CAD_Noob
add sample cad file and image
My 1 line defun call (chklay2 lay col lt)  with (setq col (acad_colordlg 1)) (setq lt "continuous")
Edited by BIGAL
Hello,
I've modified my code as per your requirement, I've kept it simpler so that you can understand it step by step.
For assigning colors you can add colors to text directly as shown in below image.
Please try following code in attached:
(defun c:test (/ laycol layer s i o v c)
  (defun laycol	(o)
    (if	(setq
	  o (vla-item (vla-get-layers
			(vla-get-activedocument (vlax-get-acad-object))
		      (vla-get-layer o)
      (vla-get-color o)
  (defun layer (name color)
    (entmake (list
	       '(0 . "LAYER")
	       (cons 2 name)
	       (cons 70 0)
	       (cons 62 color)
  (if (setq s (ssget "_:L" '((0 . "*TEXT"))))
    (repeat (setq i (sslength s))
      (setq o (vlax-ename->vla-object (ssname s (setq i (1- i))))
	    v (strcat "A-_" (vla-get-textstring o) "-N")
	    c (vla-get-color o)
      (if (eq c 256)
	(setq c (laycol o))
      (if (not (tblsearch "layer" v))
	  (layer v c)
	  (princ (strcat "\nNew layer created : " v))
	(princ (strcat "\nLayer exists : " v))
satishrajdev I think the problem is his text is one color so the get-color will return white. Perhaps at start ask add colors or use text color,  then could do a if at the (vla-get-color o) or use the (acad_colordlg 1) to pick a colour,you could also  (setq c (acad_colordlg (vla-get-color o)) then press ok or change.
1 hour ago, satishrajdev said:
Hello,
  (defun laycol	(o)
    (if	(setq
		      (vla-get-layer o)
      (vla-get-color o)
    (entmake (list
	       '(0 . "LAYER")
	       (cons 2 name)
	       (cons 70 0)
	       (cons 62 color)
	    c (vla-get-color o)
      (if (eq c 256)
	(setq c (laycol o))
	  (layer v c)
I'm thinking of selecting the text and the polyline beside each text but hey, this is still a great work-around.
Thanks a lot!
