Binding XRef's
I've been working on a plan for the past few months which we have now finalised. But we like to bind the XRef'd files to the main files we work with for the drawings.
I have successfully binded the 'design' files to the all the main drawings except one of them. There is just this one file that will not bind the 'design' files. It gives: Error: At least one of the specified xrefs failed to bind for an unknown reason.
They worked on the others, but not this one.
Any ideas? And thanks in advance.
I detached the offending drawing, then reattached it and it then appeared to have worked.
Not sure why though. Any ideas?
AutoCAD has been quirky from the start so I would chalk it up to that. Things happen in AutoCAD that just cannot be explained.
:twisted:
If they can be Autodesk is being tight lipped about most of them.
:roll:
