arash136 Posted March 24, 2020 Posted March 24, 2020 I need a lisp to make a loop to do sum and save the total numbers. for example I need to run it and type in command line 5.45, 5.55, 5.89 or more and give me a total and it doesn't matter each time how many number we are typing and each time giving us a sum and the total of numbers. May you help me please. Thank you! Quote
fuccaro Posted March 24, 2020 Posted March 24, 2020 (defun c:mysum() (setq i 0 sum 0 nr T) (while nr (setq nr (getreal (strcat "Number no " (itoa (setq i (1+ i))) "="))) (setq sum (+ sum (if nr nr 0))) ) (princ (strcat "sum= " (rtos sum))) (princ) ) Quote
hanhphuc Posted March 25, 2020 Posted March 25, 2020 command : ( + 5.45 5.55 5.89 ;|....etc....|; ) 16.89 p/s: while inputting decimal <10, eg: '0.4' you can not suppress 0 as '.4' , zero '0' must be included, ie: 0.4 Quote
BIGAL Posted March 25, 2020 Posted March 25, 2020 (edited) Fuccaro not sure why need nr T and double check, this worked ok. Happy to take comments about method not right Also CAL note Briscad opens a calculator. Cal 23+42+36 enter it does much more than + - / etc. hanhphuc nice idea. (defun c:mysum() (setq i 0 sum 0 ) (while (setq nr (getreal (strcat "Number no " (itoa (setq i (1+ i))) "="))) (princ (strcat "sum= " (rtos (setq sum (+ sum nr)) 2 3) " ")) ) (princ) ) (c:mysum) Edited March 25, 2020 by BIGAL Quote
fuccaro Posted March 25, 2020 Posted March 25, 2020 @Bigal I don't use AutoCAD these days and I decided to play Lisp when I have some time. And you know: if you (read: I) don't use it, you loose it. I remember years ago my fingers running on the keybord and usually the programs used to run more or less from the first try. Yes, I see that it works without that nr T too. We all know that a code can be more or less efficient. Maybe next time I will perform better. Have a nice and virus free day! Quote
BIGAL Posted March 26, 2020 Posted March 26, 2020 (edited) I just thought that maybe there was a reason that I was missing with just doing (while. Thinking a bit more I am pretty sure did something in past. enter 1st number type +123.45 etc follow with -23 +56.35 /23.2 it looks at the 1st character in a string and does that math action so much more than just + Did the same for draw ortho lines L123 u45 r65.78 etc. Had a few minutes (defun c:alscalc ( / ans txt calc) (setq ans (getreal "Enter 1st number ")) (setq calc "") (while (/= (setq txt (getstring (strcat "\Enter calculation +-/* Enter to exit " (rtos ans 2 3) " "))) "") (setq calc (strcat calc " " txt)) (setq is (substr txt 1 1 )) (setq num (atof (substr txt 2))) (cond ((= is "/")(setq ans (/ ans num))) ((= is "+")(setq ans (+ ans num))) ((= is "-")(setq ans (- ans num))) ((= is "*")(setq ans (* ans num))) ) ) (alert (strcat calc "\n\nAnswer = " (rtos ans 2 3))) (princ) ) Edited March 26, 2020 by BIGAL Quote
