My annotation scales are automatically updated while selecting new annotation scale. What happend ?
Is there any system variable ?
Have you checked out ANNOAUTOSCALE?
Yes it is 4, what is this ?
From AutoCAD Help:
ANNOAUTOSCALE Updates annotative objects to support the annotation scale when the annotation scale is changed
When the value is negative, the autoscale functionality is turned off, but the settings are maintained:
1 Adds the newly set annotation scale to annotative objects that support the current scale except for those on layers that are turned off, frozen, locked or that are set to Viewport > Freeze.
2 Adds the newly set annotation scale to annotative objects that support the current scale except for those on layers that are turned off, frozen, or that are set to Viewport > Freeze.
3 Adds the newly set annotation scale to annotative objects that support the current scale except for those on layers that are locked.
4 Adds the newly set annotation scale to all annotative objects that support the current scale.
From AutoCAD Help:
Now its OK..Thanks for your help..
Thanks for covering for me Tiger :wink:
No problem Chulse, it's team effort :)
Good that it worked out Vinod!
