Edited by SR211
Um, can you explain your criteria and what you're trying to achieve?
So join the dots ? Can see a mistake in your image one hor line should come from the Vertice of the block.
Example in image the tricky bit is the draw lines but using x&y from before next block.
Use bounding box will fix 90 out of block. Some one may already have a solution. Not worried about little fillet once rest of code is worked out.
Thinking more if end point is not a block draw line until block picked.
Edited by BIGAL
