Jonathan Handojo Posted March 30, 2020 Posted March 30, 2020 Um, can you explain your criteria and what you're trying to achieve? Quote
BIGAL Posted March 30, 2020 Posted March 30, 2020 (edited) So join the dots ? Can see a mistake in your image one hor line should come from the Vertice of the block. Example in image the tricky bit is the draw lines but using x&y from before next block. Use bounding box will fix 90 out of block. Some one may already have a solution. Not worried about little fillet once rest of code is worked out. Thinking more if end point is not a block draw line until block picked. Edited March 30, 2020 by BIGAL Quote
