So, I added a transparent hatch to parts of my drawing today. This drawing also has several attached PDFs that are in their own viewports. The problem is that when I go to plot the drawings, the PDFs are also going transparent. WHY PLEASE?????
DAAM - SITE PLAN.pdf
I did not download the pdf because it is a pdf and may not contain the info needed to diagnose the issue.  Can you upload the drawing?  This is probably why you have gotten few responses.
EDIT:  I went back and downloaded the pdf.  Layer information is not included which is an option in PUBLISH.  That's OK though. Layer info makes pdf files way too heavy usually.
Otherwise my guesses are that the pdf(s) were selected while you set the trans level on the hatch(es), or the transparency level is by layer and the pdf's and hatches are on the same layer.
Stop the guessing and please upload a copy of the drawing with all proprietary info deleted.
Edited by Dana W
Thank you so much. I created a zip, so you would have all files, but then, the file size was too large to load here. Would the dwg give you enough info w/out the attached pdfs? I have added it anyway.
DAAM - PLAN.dwg
