DWG slow save after a little
jim78b
i don't know after i work with a 3d drawings savings become very slowly, i must resave in other new drawing copy and paste all objects, why?
Did you try -PURGE the drawing? That is basically what Copy and Paste are doing. You may also want to run an AUDIT every once in a while.
Yes try -purge and regapps...i have autocad mech 2013 i suppose for this ?if i use aectoacad...it export to dwg and i find various layers with name :aecobjectexplode
win7 64 bit
16 giga ram
intel core 7
nvidia quadro k600
autocad mech 2013
win7 64 bit
16 giga ram
intel core 7
nvidia quadro k600
hard disk ssd
autocad mech 2013
no other programs except dropbox but i don't share or backup any files in dropbox all i saved local.
yes of course latest nvidia driver, service pack sp2 autodesk. audit tell me that dwg is correct but after  some works the drawing slow down.
Edited by jim78b
I purged the drawing and it went to less than 1.5 MB. Seems to be an AutoCAD Mechanical issue looking at the results.
Quote
-PURGE
Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/Orphaned data/All]: a
2 zero-length geometric objects deleted.
Enter name(s) to purge <*>:
Verify each name to be purged? [Yes/No] <Y>: n
Deleting block "GENAXEH".
1 block deleted.
Deleting layer "Defpoints".
1 layer deleted.
Deleting linetype "ACISOTGB".
Deleting linetype "ACISOTGL".
Deleting linetype "ACISOWELD".
Deleting linetype "AM_ISO02W050".
Deleting linetype "AM_ISO02W050x2".
Deleting linetype "AM_ISO08W050".
Deleting linetype "AM_ISO08W050x2".
Deleting linetype "AM_ISO09W050".
Deleting linetype "Amconstr".
Deleting linetype "Amzigzag".
Deleting linetype "CENTER".
Deleting linetype "HIDDEN".
Deleting linetype "PHANTOM2".
13 linetypes deleted.
Deleting text style "ACISOGDT".
Deleting text style "ACISOTS".
2 text styles deleted.
Deleting shape file "genltshp.shx".
1 shape file deleted.
Deleting dimension style "AM_ISO Layout".
Deleting dimension style "AM_ISO$0".
Deleting dimension style "AM_ISO$2".
Deleting dimension style "AM_ISO$3".
Deleting dimension style "AM_ISO$4".
Deleting dimension style "AM_ISO$6".
Deleting dimension style "AM_ISO$7".
Deleting dimension style "AM_ISO$SF".
Deleting dimension style "AM_ISO$SH".
9 dimension styles deleted.
No unreferenced mlinestyles found.
No unreferenced plotstyles found.
No unreferenced table styles found.
No unreferenced materials found.
No unreferenced visual styles found.
No unreferenced multileader styles found.
No unreferenced groups found.
No unreferenced Detail view styles found.
No unreferenced Section view styles found.
Command:
-PURGE
Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/Orphaned data/All]: r
Deleting registered application "ACAD_DSTYLE_DIMANGULAR_EXTENSION".
Deleting registered application "ACAD_DSTYLE_DIMARC_LENGTH_SYMBOL".
Deleting registered application "ACAD_DSTYLE_DIMINSPECT".
Deleting registered application "ACAD_DSTYLE_DIMJOGGED_JOGANGLE_SYMBOL".
Deleting registered application "ACAD_DSTYLE_DIMRADIAL_EXTENSION".
Deleting registered application "ACAD_EXEMPT_FROM_CAD_STANDARDS".
Deleting registered application "ACAD_MLEADERVER".
Deleting registered application "ACAD_OBJECT_CHANGE_GUID".
Deleting registered application "ACAD_TEMP_GRAPHIC".
Deleting registered application "AcadAnnoPO".
Deleting registered application "AcadAnnotative".
Deleting registered application "ACADM_DIM_EDIT".
Deleting registered application "AcAecLayerStandard".
Deleting registered application "ACATTRIBSERVICES".
Deleting registered application "ACM_PP_ASSOCVAR".
Deleting registered application "ACM_PP_DIM_ACTION_MACRO".
Deleting registered application "ACM_PP_DIM_CONSTRAINT".
Deleting registered application "ACM_PP_DIM_CONSTRAINT_DRAG_GRIP".
Deleting registered application "AD_DRAW".
Deleting registered application "AMDT_DM_ADJ".
Deleting registered application "DCO15".
Deleting registered application "DESIGNERASSEMBLIES".
Deleting registered application "GENIUS_AMGTXT_16".
Deleting registered application "GENIUS_GENBH_13".
Deleting registered application "GENIUS_GENCEN_19".
Deleting registered application "GENIUS_GENDTOL_13".
Deleting registered application "GENIUS_GENHATCH_13".
Deleting registered application "GENIUS_GENOBJ-N-CEN_13".
Deleting registered application "GENIUS_GENOBJ-N-HTC_13".
Deleting registered application "GENIUS_GENOBJ-N-SDF_13".
Deleting registered application "GENIUS_GENOBJ-N-ZOO_13".
Deleting registered application "GENIUS_GENOBJ-NBEHI-BHB_13".
Deleting registered application "GENIUS_GENOBJ-NBEHI-BHF_13".
Deleting registered application "GENIUS_GENOENT_13".
Deleting registered application "GENIUS_GENOLIS_13".
Deleting registered application "GENIUS_GENOREF_13".
Deleting registered application "GENIUS_GENSCREG_15".
Deleting registered application "GENIUS_GENZOO_17".
Deleting registered application "GEVID1566572766".
Deleting registered application "GEVID1566572768".
Deleting registered application "MCAD_NO_VIS".
41 registered applications deleted.
Maybe, not sure what that Genius stuff is from. I did several things to your drawing and saved and saved and saved some more in AutoCAD 2018 and sized stayed pretty much the same.
Maybe someone else with more time can dig deeper for you.
Okay, so that is AutoCAD Mechanical as well.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-remove-the-GENAXEH-block-from-an-AutoCAD-Mechanical-drawing.html
thanks very much you are a genius! thanks to all !!! but is this the cause of slow savings?
Edited by jim78b
Like I stated, no slow saves on my computer with AutoCAD 2018 (that's even with me remoted into the computer at work), so I would say that it is an AutoCAD Mechanical issue and/or an issue with your computer, possibly some settings. I used to avoid using any Mechanical specific things unless needed, way back when I used Mechanical, though I don't recall any problems, but it has been a while.
