Cannot Edit Multileader Text
For some reason I am now unable to edit text in my multileaders (already in a particular dwg). Any clues?
I can edit newly created multileaders, just not the existing ones.
what does it say when you try? have you tried useing DDEDIT? Is the layer locked?
It doesn't say anything. I double click and it behaves as if I did nothing. If I go through the properties box it allows me to think I'm editing it, but then when I click OK in the text editor it reverts back to what was there.:x
Ah. I closed and reopened the dwg and all seems fine now. Foolish multileaders! How dare they toy with my emotions on a Monday morning like that!
:lol: AutoCAD is evil that way.
If your multileaders are annotative, try running an audit (you don't need to answer Y to correct the problems); this usually fixes the 'can't select' problems with annotative objects.
I'll still take any evil little glitches in mleaders over a return to qleaders any day though.
You should try to avoid AutoCAD on Mondays, Fridays and on your birthday... :D
