grain Posted February 2, 2009 Posted February 2, 2009 Yippee we've got snow Oops sorry:oops: I'm wanting to insert a block and specfiy its 'draw order' Ive tried to use the 'draworderctl' command but it doesnt seem to change the inserted blocks drawing order. Any tips would be gratefully received. Quote
darn-net Posted February 2, 2009 Posted February 2, 2009 You may want to select the objects in order first to last when creating the block. The DRAWORDER command lets you move objects from front to back, back to front etc. I've had trouble with Attributes in a block in the past and have found if you select all the objects with a window the order gets scrambled. "Most of what I know came from the "F1" key" Quote
